I cant say for sure which side should be higher, but I'm pretty sure that certain small blk frame mounts have different heights side to side. The repro mounts I ordered are 1/2" different height from left to right but I may have mixed them up so I cant say for sure which side is which.
If you look in some catalogs, you will see that there is one part # for both rh/lh sides of 69 302 and 350 sm blk Camaros.
The mount listed for 1967 283, 1967-68 302, 1969 307, 1967-69 327, and 1967-68 350 Camaros have different part #s for the lh and rh side.
