Which HEI? - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 11th, 01, 01:59 PM Thread Starter
Ok guys, this one is starting to get to me...has anyone found a HEI (probably small body) that will fit in their 1st Gen Camaro without any firewall hammering? If not, I"m considering Pertronix, but I've heard good and not so good things about them. Help!
69 RS 350 (under construction)
98 GMC Sierra 1500, Z-71, X-cab, K&N
budman93 is offline
post #2 of 8 (permalink) Old Jan 11th, 01, 02:39 PM
Well if you hammer very good no one will ever tell the big cap hides all did this crude thing on my old 69 or go aftermarket.
snake is offline
post #3 of 8 (permalink) Old Jan 11th, 01, 02:48 PM
Just got my Pertronix tonight. Will install it this weekend and let you know. Looks very simple.
arley is offline
post #4 of 8 (permalink) Old Jan 11th, 01, 03:56 PM
i installed an HEI with out a problem... but is very close ( 3/16" ) to firewall.
My '68 Camaro
Doug G.
68 Camaro
406 ci.
post #5 of 8 (permalink) Old Jan 11th, 01, 05:05 PM
mccorry's Avatar
I installed an MSD RtR billet distributor which is a small body dist. It has the spark amplification circuits in the base and uses a std. coil.
Works excellent!
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> www.mindspring.com/~mccorry (updated 12/22/00)
[This message has been edited by mccorry (edited 01-11-2001).]
mccorry is offline
post #6 of 8 (permalink) Old Jan 12th, 01, 08:39 AM
I installed a GM HEI on my 68 396 & it fits close but I required no hammering. The fit seems to change from car to car though. You can always go down to the local parts store buy a stock replacement and try it. If it fits then you know, if it doesn't just take it back. If it doesn't though I would personally look for a smaller body before I brought the hammer out!!!!!!
Hammering is easier than Dehammering
NORTHERN FRIEND is offline
post #7 of 8 (permalink) Old Jan 13th, 01, 10:11 AM
Installed the Pertronix today. Piece of cake. The only problem was the magnetic ring was warped and the pickup distance was a little hard to determine.
Seems to work fine.
arley is offline
post #8 of 8 (permalink) Old Jan 13th, 01, 01:34 PM
Get a hold of Ignitionman. He will convert your stock points distributer to to an HEI. This is what I did and it works great and looks/fits like stock. IMO this is the only way to go.
RickB1B is offline
