engine decode - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 15th, 04, 10:52 AM Thread Starter
hello i was wondering if you could help me in decoding an engine block.was wondering what size it was and if it was a numbers matching car.the car is a 68 rs car 4 speed
the code on the front of the motor is
18D144926 TO16HF.thanks
collision68 is offline
post #2 of 7 (permalink) Old Dec 15th, 04, 11:06 AM
Guess
HwyStarJoe's Avatar
1966 HF 327 Powerglide, A.I.R. 275hp 4bbl full size
1969 HF 350 Powerglide 275hp 2bbl A F X
1978 HF 350 LM1 170hp 4bbl Firebird
That VIN is not from a 1968 RS Camaro. I imagine it's a 350ci from a 1978 Firebird going by those numbers, but they didn't use a D plant code in 1978, did they?
HwyStarJoe is offline
post #3 of 7 (permalink) Old Dec 15th, 04, 11:25 AM
D = Doraville GA. Doraville opened in 1947 but I don't know what they were building in 1968, except that it wasn't Camaros. Later on the plant made Mini Vans like the Pontiac Transport, Chevrolet Venture, and Old Silhouette.
The partial VIN 18D indicates the engine is from some kind of Chevrolet vehicle built in 68, or 78 at the Doraville plant.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #4 of 7 (permalink) Old Dec 15th, 04, 11:37 AM
Vintage 68's Avatar
I had a '68 Impala with a 327 4Bl Rochester that was a "D" Atlanta built car.
Don't know if they built other than Full size there though.
1968 Convertible
Some trucks
Vintage 68 is offline
post #5 of 7 (permalink) Old Dec 15th, 04, 12:40 PM
Smile
Look back either above/on top of the oil filter boss or the top of the bellhousing lip and you should be able to find a casting date code. That will clear it up..
pdq67
post #6 of 7 (permalink) Old Dec 15th, 04, 01:46 PM
Kevin
KevinW's Avatar
It's a 68 327/275 th350 with a 4bbl from a full size car built in Doraville, ga. The info is right in CBTN. Block number should be 3914678 or possibly 3914660.
Kevin
KevinW is offline
post #7 of 7 (permalink) Old Dec 15th, 04, 05:05 PM Thread Starter
thanks guys for the help
