700R4 acting funny - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 4th, 02, 11:12 AM Thread Starter
I know this isn't Camaro related, but I'll ask anyway. I have a '95 Chevy pick-up with a 4.3?V6 and a 700R4 with close to 148,000 nearly trouble free miles on it. Back to the trans...I've had no problems and done nothing to it since it was new. Last Friday it was fine, but when I went out that night it acted like the motor was revving much more than normal for the acceretaion, as if something wasn't hooking up...I think overdrive was gone too...still drivable, but acting different. That was the only incident until yesterday coming home from work. It was fine this morning and did it again on the way home. If it has a passing gear, which it usually seems to have, it's not working either during the times it acted up. I haven't heard any noise or noriced any slippage, just slow acceleration in a higher than normal RPM range and the lack of OD and a passing gear. Any ideas?
Glenn1018 is offline
post #2 of 6 (permalink) Old Apr 4th, 02, 11:26 AM
BC
Have you checked the tranny fluid? That's one of the first signs of low fluid... otherwise, the tranny probably needs a rebuild...
Bill C.
Bill C.
Colorado Springs, CO
68 Camaro... someday!
71 Chevelle SS
70 Nova
BC is offline
post #3 of 6 (permalink) Old Apr 4th, 02, 12:55 PM Thread Starter
I did, and the fluid level was good. I hope it doesn't need a rebuild.
post #4 of 6 (permalink) Old Apr 4th, 02, 08:36 PM
maybe change the fluid and filter. if you haven't ever even had to look at the tranny, maybe it has never been changed.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
post #5 of 6 (permalink) Old Apr 5th, 02, 12:45 PM
Does the fluid smelled burnt? You can compare with new fluid smell. Burnt=bad.
68 RS, Ash Gold,pwr brakes,pwr windows,Hounds tooth,355/T350,MSD 6AL,3200 stall Dynamic converter,3.31:1 posi,Autometer guage pod
CA420 is offline
post #6 of 6 (permalink) Old Apr 5th, 02, 03:35 PM Thread Starter
It's even funnier than I imagined...I called a parts store and found out it's either a L60 or a L80, depending on the amount of pan bolts. I'll count them in the morning. Thanks for the help...this is a good site.
