Harmonic Balancer - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 15th, 03, 05:15 PM Thread Starter
Unhappy
I have the problem you mentioned in a post I pulled up on the net concerning a stripped Harmonic Balancer bolt. Mine let go while turning the engine over, I am now the proud owner of a crank socket. Thought someone might be able to give me some insight as to the fix. I have talked to many people, all with different opinions. They range from installing a heli-coil to tapping to the next size bolt. I was told it was not a good idea to use a heli-coil in this particular application, but then was told that making the size larger by tapping, thus making the wall thinner, was also not a good idea. Help!
'72 Camaro<br />'69 350 40 Over<br />World Sportsman II
cartboy67 is offline
post #2 of 8 (permalink) Old Aug 15th, 03, 07:23 PM
either way should work- but I'd tap it out to the big block Chevy size and not worry about it- that's the cheapest way to do it, and i don't think it will make it much weaker- in fact, it might be stronger. who knows?
you don't plan sincerity.
novaderrik is offline
post #3 of 8 (permalink) Old Aug 16th, 03, 10:12 AM
How would you make sure the new hole was straight? I don't think I can aim a drill that well.
jimfulco is offline
post #4 of 8 (permalink) Old Aug 17th, 03, 10:56 AM Thread Starter
novaderrik..took your advice, long hard job just to retap a hole, but came out with good results...thanks
post #5 of 8 (permalink) Old Aug 17th, 03, 11:47 AM
David Pozzi
davidpozzi's Avatar
Moral of this story: Don't EVER turn over an engine using the crank bolt.
davidpozzi is offline
post #6 of 8 (permalink) Old Aug 17th, 03, 07:04 PM
JohnZ's Avatar
David, how many times have we said that?
JohnZ
CRG
JohnZ is offline
post #7 of 8 (permalink) Old Aug 18th, 03, 06:03 AM
Any reasonable alternatives out there?
BPOS is offline
post #8 of 8 (permalink) Old Aug 18th, 03, 07:02 AM
Robert
Here's one.
http://www.jegs.com/cgi-bin/ncommerc...23&prmenbr=361
I need to buy one myself.
Robert
TC member #18
rojo is offline
