302 Hemi - Team Camaro Tech
post #1 of 20 (permalink) Old Jan 26th, 05, 04:05 AM Thread Starter
Tony
Looking at some pictures of the hemi in a book
looks like it has flat top pistons wonder what
the compression ratio was anybody know?
Tonyx33 is offline
post #2 of 20 (permalink) Old Jan 26th, 05, 04:16 AM
Johnny
Post some pic's if you can & all the info that you can get, I for one would love to see it.
johnnyr is offline
post #3 of 20 (permalink) Old Jan 26th, 05, 04:25 AM Thread Starter
Tony
No way to post pics but there some in John
Hooper 69 Camaro Reference book.
'69 Frost Green Z/28
Tonyx33 is offline
post #4 of 20 (permalink) Old Jan 26th, 05, 02:32 PM
Smile
Those aren't real SB hemi-heads, but rather, "mini-BB, splayed valved" type instead.
I don't think Chevy ever made a true MOPAR hemi-head for the SB..
If I was so inclined to try to install HH's on a SB, I would look closely at the '50's MOPAR hemi-head motors and try to find one that had as close a bore spacing as the 4.4" bore spacing the SB has and then figure out a way to redrill the decks and bolt them on!! Then figure out how to create the valvetrain and intake so everything would work...
BUT it would be a heavy bugger just like the old MOPAR hemi motors were back then!! AND it would breathe like there's no tomorrow!!!
pdq67
post #5 of 20 (permalink) Old Jan 26th, 05, 06:08 PM
SY1
Tony the pics in John's book don't really show the dome well. They actually had a dome over the entire top of the piston. The domes were cut quite deeply to accomodate the splayed valve angles. I purchased a new never run set of standard bore pistons from Yunick some years ago. I gave up on putting the engine together because I felt there were better choices out there for the cost. Most of the obstacles can be overcome, you can have a camshaft custom ground, have a custom set of headers built, clearance the lifter bores for the pushrods angles, gaskets can be made, a sheet metal intake can be fabricated and you can use the standard 302 crossram lid.
A splayed valve head is still available from GM, but no hardware for the valve train is offered. Moroso makes a valve cover for the head.
Back to the pistons, I sold them a few years ago, still unused. The only picutre I still have of them has one of them out of the box and turned sideways and you can see the intake relief cut into the dome extends almost all the way down to the top compression ring groove. Someone at Smokey's shop had written some numbers and letters in marker on the pistons, but I couldn't tell where it meant anything really.
The book Camaro Untold Secrets has a little better picture on page 122 of the dome of the piston part number 3865534. The engine isn't really a true hemi, but rather a modified semi hemispherical design as the book states, closer to the big block Chevy. But it is an interesting experiment.
By the way the pistons I purchased a set of the standard 302 pistons from Yunicks that were very heavy modified, with a lot of material removed to lighten them. The "hemi" pistons probably weren't modified but due to the age and oxidation you wouldn't be able to easily tell. Smokey apparently liked to mill a lot of material from the piston including the skirt and balance pad areas below the pin bore and the 302 had a very low pin location to begin with. He also had cut the valve reliefs deeper to allow for additional lift camshafts, he liked to use higher ratio rockers like the 1.7:1s from what I've read. The "hemi pistons" didn't appear to be reworked in this area.
I've never bothered to set up a site to post pics from, but if someone here has the ability to post pics and is interested I can send a copy of the pic of the pistons, but I think the Camaro Untold Secrets book has a better picture and it's highly recomended reading.
[ 01-26-2005, 08:22 PM: Message edited by: SY1 ]
SY1 is offline
post #6 of 20 (permalink) Old Jan 26th, 05, 06:46 PM
SY1
Forgot to answer your question regarding comp ratio. Really not sure, all I've read is Camaro Untold secrets says 12.5:1, but also notes 12:1. I've also seen somewhere mentioned in another article as 13:1.
"..............what, and get out of aviation??"
SY1 is offline
post #7 of 20 (permalink) Old Jan 27th, 05, 03:34 AM Thread Starter
Tony
Thanks the pictures look like flat tops
but there in black & white
Tonyx33 is offline
post #8 of 20 (permalink) Old Jan 27th, 05, 04:56 PM
SY1
Tony they look like flat tops more than they look like the dome we're used to seeing on SBC pistons. They are actually a mild radius across the face of the piston with the high point in the center that creates the dome, not like the large sharp dome most SBC pistons are known for.
SY1 is offline
post #9 of 20 (permalink) Old Jan 27th, 05, 04:58 PM Thread Starter
Tony
Tonyx33 is offline
post #10 of 20 (permalink) Old Jan 28th, 05, 06:53 AM
Hey PDQ, your idea is one that my cousin and I worked on in the mid 70's. We took a 331 hemi head, and attempted to fit it onto a 340. We thought, what could be better than a HEMI-340? High winding, great breathing, etc. Some guys had done it with the 440, redrilled and installed 426 heads on it. It seemed to perform pretty good. But what a nightmare the 340 HEMI project turned out for us. We finally abandoned it, the expense was getting outrageous, and no machine shop seemed to want to grasp the concept and run with it. Also about then, MOPAR came out with the W2 head, which took care of the 340's breathing problems. But we were there! Also, I always kinda figured that Smokey Yunick would have adapted a hemi head onto the small block Chevy if it could have been done. So I don't have too much hope there. What do you think?
nothinbuttaillights is offline
post #11 of 20 (permalink) Old Jan 28th, 05, 11:12 AM
Jeff
Chevrolet made around 8-10 sets of hemi heads and testing showed that a set of 186 heads ported by Traco made the same power as the hemi heads. So it wasn't worth the investment to make them since they wouldn't work on a street engine anyway. I'm not sure what the pistons looked like but they were some sweet looking heads.
Jeff H
69 Z28 Hugger Orange original factory JL8 brakes, being restored
Jeff H is offline
post #12 of 20 (permalink) Old Jan 28th, 05, 12:03 PM
I distinctively remember seeing a motor with those heads in Smokey Yunicks shop. It was a topic of discussion that lasted for hours.
67CruiseMasterCamaro is offline
post #13 of 20 (permalink) Old Jan 28th, 05, 02:25 PM
Dang, I just did a search and there IS a company making true Hemi heads for small block Mopars! Not re-welds! Now I want to see independant testing of them versus the W2 head, or some other aftermarket aluminum heads. If they do outperform wedge heads, then maybe they will make them for the small block chevy, also, someday! We can only hope!
post #14 of 20 (permalink) Old Jan 28th, 05, 03:07 PM
Smile
I figure that the reason hh's didn't perform all that much better then reworked wedge's is b/c our motor's bores and overall size is just too small compared to a B&S MOPAR hemi race motor.
May be wrong, but why go to all that trouble to install them unless something is going to improve big-time!!
Now the idea I have had about putting 409 "W" motor heads on a 454 motor and using figure-8 dished pistons to create max. torque like Mr. Fueling did intrigues me to no end!! BUT only from a low cost standpoint deal.. "Shade-tree" deal is all.....
As does Pete Ardema's SOHC conversion on stock, SB heads....
pdq67
post #15 of 20 (permalink) Old Jan 28th, 05, 03:08 PM
Jeff
I think there are 3-4 of the 302 hemi motors assembled. Charley had one in a car, Floyd's museum had one and I forget if there was 1 or 2 others. In Wayne's book, the pistons are domed with serious valve reliefs cut into them for clearance. They are listed as 12:1 compression pistons. They are not flat-top pistons.
Jeff H
Jeff H is offline
