350 engine numbers? - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 18th, 04, 07:15 AM Thread Starter
trying to find out where my engine came from, the rear housing # is 3970010 and the pad # is k02 07 tky. if nay knows them or can tell where to find out thanks.
hoffa is offline
post #2 of 9 (permalink) Old Sep 18th, 04, 07:26 AM
Vintage 68's Avatar
You have a McKinnon Foundries LS-9 350 from a mid to late 70's Truck. You will need to find and check the casting date to make a better quess as to which year unless you can find the partial VIN and decode it for application.
These are usually good 4-bolt bolts for mild performance builds depending on the past use and repairs to the motor.
Most of the heads used on these motors are junk for reuse on a performance motor. They are also very prone to cracking even in normal use.
Hope some of this helps
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 9 (permalink) Old Sep 18th, 04, 07:40 AM Thread Starter
thanks for your info, the heads are not from the this engine, #'s are 3970126 on the heads.
hoffa is offline
post #4 of 9 (permalink) Old Sep 18th, 04, 02:50 PM
Hi Vintage, I'm looking for the same as "hoffa," can you help me out? I think it's out of a dump truck from "74".....#s K09 14 TJC
Thanks, Rich
Royal Blue 69 Z28 is offline
post #5 of 9 (permalink) Old Sep 19th, 04, 04:48 AM
Guess
HwyStarJoe's Avatar
1973-74 TJC LS-9 350ci conv.cab - 155-160hp 4bbl C-20 to 3500
HwyStarJoe is offline
post #6 of 9 (permalink) Old Sep 19th, 04, 05:59 AM
TKY = 1974 trucks, C20
and K20, 350, four barrel, 160hp, TH350/400 A/T.
pdq67
post #7 of 9 (permalink) Old Sep 22nd, 04, 08:35 PM
help. same as everyone else. i pretty much have every number written down off the egine. D5 6(April 5, ?6) is the casting. how else can i find the date? which numbers tell me where it came from? and i have the 010 and 020 marking on the block. i was going to sell it because i just put a down payment on a new 383, but i read this block is rare. how valuable?
mr. black is offline
post #8 of 9 (permalink) Old Sep 23rd, 04, 06:21 PM
click's Avatar
Lets have Bill move this to Tag section where the number guru's hang out [img]smile.gif[/img]
click is offline
post #9 of 9 (permalink) Old Sep 24th, 04, 06:43 AM
Vintage 68's Avatar
Originally posted by mr. black:
help. and i have the 010 and 020 marking on the block. i was going to sell it because i just put a down payment on a new 383, but i read this block is rare. how valuable?
High Alloy blocks are not "rare" - they are very common in HD/truck/marine use...
Standard high production passenger blocks do not need 'exotic' alloys to survive and give good service life.
by 'Click'
"Lets have Bill move this to Tag section where the number guru's hang out"
[img]graemlins/thumbsup.gif[/img]
1968 Convertible
Some trucks
