383 450hp & 442ftl torque - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 25th, 03, 01:21 AM Thread Starter
I wonder if a stock Camaro 68 can stand that kind of power?
have a TH350 in it now with raybestos and shiftkit. The rear axle is a 10-bolt stock for Powerglide.
Rear tires are 17" 265/40 (not that much grip)
I also have solid aluminum SF bushings and soon also SF connectors.
Or do i need to change a lots of stuff and reinforce some other stuff?
<a href="
target="_blank">Camaro RS 68</a>
MagnusRS68 is offline
post #2 of 4 (permalink) Old Oct 27th, 03, 02:32 AM
yes it can. only when you beat on it will you tear things up. If your transmission is old (even with a shift kit) the clutches may slip.
I had a 300 H.P. 350 in a 3500# firebird, didnt have any problems until I took it to the track, the tranny did not like it one bit! I was runnin on street tires too!
Frame ties are always a good idea if youre going for any kind of performance.
67 camaro, frame off resto/street strip. 383 tremec 5-speed, moser 9" 4:11, still under construction, 5 years running...needs paint and interior to be complete.
QUIK CAM is offline
post #3 of 4 (permalink) Old Oct 27th, 03, 03:35 AM
Eric
You definately need the subframe connectors. A set of no-hop bars for the rear springs would be important too. The aluminum body bushings are also a good idea.
Other than that you should be fine.
PS. One thing I did to my 68 was to install a tubular driveshaft loop. I welded a tube going across the car between each subframe connector and welded the loop over the driveshaft to that. The extra tube between the subframe connectors make the setup even a little more rigid IMO.
Eric68 is offline
post #4 of 4 (permalink) Old Oct 28th, 03, 01:12 AM Thread Starter
I guess that my rearend and gearbox will stand the new power till i put on some slicks. [img]smile.gif[/img]
My 327cid is cabable of small "burnouts" as it is.
<a href="
