68 camaro frame mounts - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 22nd, 15, 09:57 PM Thread Starter
Tony
68 i got had a previous bbc in it per previous owner but i cannot confirm it as he sold me the car as a roller. i am putting a 350, however i cannot tell the difference between the small block and big block motor frame mounts even looking at pictures from catalogs or computer, If i put the small block in and its big block frame mounts how much problems would i see, does this raise the motor up higher ? or move the motor over any? Just wondering before i put it in i dont waste my time. Thank you
nitro63 is offline
post #2 of 5 (permalink) Old Jun 23rd, 15, 04:29 AM
kevin
Re: 68 camaro frame mounts
my 68 was an original BB car with 4 speed and now has a SB. 4 speed it has no power steering or AC. it does have a 11" brake booster.
the only problem I had was with the hooker super comp. headers. I had to dimple one tube for the idler arm and one tube for the pitman arm
this is using the BB frame and transmission mount
flat tire is offline
post #3 of 5 (permalink) Old Jun 23rd, 15, 09:56 AM
Smile Re: 68 camaro frame mounts
It all depends on what has already been changed. Yes, you can do it, but I would advise you not to.
What big block stuff do you have ? You will have to use things such as Radiator shroud, Z-bar (if four speed) for a Big Block.
The engine frame mounts and transmission move the engine 1/2" to the passenger side and 3/4" forward from the small blocks location.
The biggest problem may or may not be the headers.
TJS69 is offline
post #4 of 5 (permalink) Old Jun 23rd, 15, 11:02 PM Thread Starter
Tony
TJS69 not sure if you are repling to my comments or back to flat tire comments, but mine is the same as above, just need to know how to determine if the frame mounts are bbc or sbc and yes or no on issues putting a sbc on bbc mounts, Thank you
nitro63 is offline
post #5 of 5 (permalink) Old Jun 24th, 15, 01:33 PM
SBC mounts are usually about the same in height. For a BBC the drivers side mount is taller.
TJS69 is offline
