fuel tank filler neck - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 18th, 03, 03:29 AM Thread Starter
Anyone with any experience on changing out a fuel tank filler neck? Mine is cracked and bent, so I ordered a new one and was wondering if anyone could give me tips on installation...
thanks [img]smile.gif[/img]
mimran is offline
post #2 of 3 (permalink) Old Aug 18th, 03, 03:59 AM
67 - 68 , open trunk, remove boot,hose clamp at neck, and 3 screws under gascap. Pull out neck... reinstall in reverse order.
68 Camaro~LSx ~all motor
post #3 of 3 (permalink) Old Aug 19th, 03, 12:01 PM
Its as easy as Doug says! I think it took me about 15-20 minutes a couple of weekends ago.
If it's still the rubber peices from the 60's, you might want to consider replacing them while you're there (the filler sleave and the boot). I know Rick's and Classic Industries have them and I don't remember it being that expensive.
Grey67 is offline
