Part throttle pinging - Team Camaro Tech
post #1 of 25 (permalink) Old Jun 25th, 15, 09:19 AM Thread Starter
Greg
I have been experiencing a part throttle pinging lately. It seem to occur right off of idle during part throttle acceleration. When I am running at cruising speeds I do not hear it and also don't hear anything under WOT. The pinging is not solid steady pinging, it is just a random one. Here is what I have tried to fix the problem:
1. Checked my timing and I have 14 degrees initial with this http://www.speedwaymotors.com/Speedw...utor,1688.html distributor. Retarding the initial timing doesn't seem to make a difference other than it making less HP.
2. Adjusted my carb idle mixture etc and made sure there isn't a power valve issue. No fuel leaking into the throttle body at all.
3. Checked for vacuum leaks and have none.
Here is what I am running in my engine:
350 bored .030 with flat top pistons with 4 valve reliefs.
64cc double bump heads with 1.6 roller rockers.
Isky 304 Megacam http://www.summitracing.com/parts/is...1304/overview/
Edlebrock Victor Jr. intake.
Holley 4010 750 double pumper.
Any suggestions are welcome.
gphusker is offline
post #2 of 25 (permalink) Old Jun 25th, 15, 09:23 AM
mike
Re: Part throttle pinging
I once had a car with a similar distributor. They have adjustable vacuum advances. Take a long allen key and insert it in the vacuum port and turn it(not sure if it is in out out). I would almost guaranty that is the problem, too much vacuum advance.
bigblockragtop is offline
post #3 of 25 (permalink) Old Jun 25th, 15, 09:26 AM Thread Starter
Greg
I forgot to add that I don't have the vacuum advance hooked up, it's capped off. I had it hooked up and made it worse.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #4 of 25 (permalink) Old Jun 25th, 15, 09:40 AM
George
Gbauer's Avatar
What gas are you using?
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #5 of 25 (permalink) Old Jun 25th, 15, 09:51 AM
Den
DenRS's Avatar
So you don't have any hesitations when stepping on the throttle at any other times? If it happens every time you step on the throttle, try increasing the squirter size. If this condition only occurs right off throttle when cruising, try jetting up the primaries.
DenRS is offline
post #6 of 25 (permalink) Old Jun 25th, 15, 11:04 AM Thread Starter
Greg
I am using 91 octane premium.
Also needed to add that it has just been a recent problem. Never had any issue before even running with 89 octane.
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #7 of 25 (permalink) Old Jun 25th, 15, 11:06 AM Thread Starter
Greg
I do have a slight hesitation at times. It's kind of always been there but the pinging is a more recent thing. Squirter size could be a possibility. I have 79 jets in the primary and 81's in the secondary. Pretty big jets for a street car, possible I guess.
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #8 of 25 (permalink) Old Jun 25th, 15, 11:25 AM
mike
Your timing mark could be off or you have more compression then you think. You also could be building up carbon on the pistons and valves which would cause higher compression and hot spots causing detonation. I am not a pro mechanic just throwing these ideas out there.
post #9 of 25 (permalink) Old Jun 25th, 15, 11:30 AM
mike
Years ago we used Marvel mystery oil down the carb to get rid of carbon deposits. Sometimes running a pvc will suck a lot of oil fumes into the cylinder causing carbon deposits.
post #10 of 25 (permalink) Old Jun 25th, 15, 11:50 AM Thread Starter
Greg
I think Seafoam does the same thing. Be worth a try and cheap I guess.
One other thing I was thinking about was if my transition circuit on my carb was gunked up or something? Although I would think I would be past that when accelerating.
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #11 of 25 (permalink) Old Jun 25th, 15, 01:19 PM
mike
I also noticed the jets do seem large and this could cause a rich condition which might help build up carbon. Do you run an air fuel ratio meter for tuning or how do the plugs look? Plugs could be to high of a heat range also??
post #12 of 25 (permalink) Old Jun 25th, 15, 07:29 PM Thread Starter
Greg
The carb came new with 79's in primary's and secondaries. No air fuel ratio meter but at the track we found the best combo was 79/81. It doesn't seem to be too rich just from seat of the pants feeling. At this point I am almost willing to look at any option really.
gphusker is offline
post #13 of 25 (permalink) Old Jun 25th, 15, 08:19 PM
scblucam's Avatar
You know with that cam I don't see all of the specs but would think you have a lot of overlap decreasing your compression at lower RPM's. You sure it is ping and not something else happening?
68 302 M20 - 85 IROC Z
scblucam is offline
post #14 of 25 (permalink) Old Jun 25th, 15, 10:22 PM
mike
What do the plugs look like?
post #15 of 25 (permalink) Old Jun 26th, 15, 03:37 AM Thread Starter
Greg
I haven't got a chance to pull plugs or anything. Hopefully have some time this weekend. I may just pull my valve covers off and make sure there isn't anything obvious and also check the plugs.
gphusker is offline
