is this the right starter? - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 20th, 04, 12:07 PM Thread Starter
Rob
Red face
please help,I have a 68 327 cid block & a 13"?flywheel w/153 teeth.I was'nt sure what starter to get,,,,,, anyway I got a delco/remy 1998237.sometime it does'nt grab right.is this the right starter?or is there one with bigger teeth that would grab better? thank's
PAWS 67
roberttalsma is offline
post #2 of 9 (permalink) Old Dec 20th, 04, 07:10 PM
hey robert - there are two flywheels 153 and 168 tooth. The 153 tooth flywheel uses the straight across bolt hole's in the block and starter, the 168 tooth flywheel requires the use of a starter with the diagonal bolt pattern...hope this helps. There is a difference in nose cone with manual or automatic as well! nick
[img]graemlins/beers.gif[/img]
Rat Touring 1969 Camaro X44 496 Richmond Super T10 Plus 4-Speed 3.55 4 wheel disc
..and sporting all new suspension, wheels, etc etc... take a look...
nick V is offline
post #3 of 9 (permalink) Old Dec 22nd, 04, 08:15 AM Thread Starter
Rob
Smile
Thanks for the reply Nick.That info is helpfull,I do have the corect starter as far as the bolt pattern goes.I'm hooking it up to a 400 automatic trans.I'm just trying to make sure I have the right starter as far as thickness of the gear on the starter goes.I dont know if that verries. [img]graemlins/clonk.gif[/img]
PAWS 67
post #4 of 9 (permalink) Old Dec 22nd, 04, 09:09 AM Thread Starter
Rob
Wink
Upon closer examination I discovered I do not have 153 teeth like I earlir thougt but rather 168 teeth!Sorry for that error.And I do have a starter with diagnol bolt holes. [img]graemlins/clonk.gif[/img] [img]graemlins/clonk.gif[/img]
PAWS 67
post #5 of 9 (permalink) Old Dec 23rd, 04, 07:50 AM Thread Starter
Rob
Red face
Everyone must really think I'm nuts.I got a new starter,not actualy new but rebuilt,just like the other one.I droped the first one and a piece of plastic broke off.This time I also put on the bracket that holds the front to the block.I had to order that since I did'nt have one.I hope that helps.I'll find out when I turn the key.
PAWS 67
post #6 of 9 (permalink) Old Dec 23rd, 04, 01:25 PM
sometimes you need to put a shim between the starter and block to get things to mesh correctly.
you don't plan sincerity.
novaderrik is offline
post #7 of 9 (permalink) Old Dec 23rd, 04, 02:29 PM Thread Starter
Rob
Angry
Thanks for the reply and tip.I thought a shim would take the starter further away from the flywheel. [img]graemlins/waving.gif[/img]
PAWS 67
post #8 of 9 (permalink) Old Dec 23rd, 04, 03:40 PM
If you use the same size shim on both bolts then yes it brings it away, but a single shim on one or the other bolt can cause the starter to engage properly with the flywheel.
and
Brian Lewis is offline
post #9 of 9 (permalink) Old Dec 24th, 04, 08:18 AM Thread Starter
Rob
Thumbs up
Hey Brian,thanks for the reply and info.How do I know if I need a shim or not,other than the starter making a wineing sound or not.No,mine isn't making a noise,I have'nt turned the key yet. [img]graemlins/waving.gif[/img]
PAWS 67
