Need advice on tune up of 2002 Camaro V6 - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 26th, 15, 07:19 PM Thread Starter
Ken
I'm going to help my son tune up his 02 Camaro. Is there any tricks to pulling the plug wires off the spark plugs? They have a boot and a heat shield. I don't want to pull on one until I know I'm not going to screw it up. Attached is a pic of them.
Any other tips on replacing plugs, wires and fuel filter would be appreciated.
Name:	Spark Plugs passengers side.jpg
Winch is offline
post #2 of 2 (permalink) Old Jun 27th, 15, 01:24 PM Thread Starter
Ken
Re: Need advice on tune up of 2002 Camaro V6
I went ahead and pulled a wire off the plug. The boot and heat shield all come off together. There is a spring on the end that I've never seen before. So putting a new set of plugs in should be easy. If anyone has experience with these newer engines I'd appreciate any heads up about known problems doing what I am doing.
Winch is offline
