67 Camaro 210 HP 2 Barrel Carb Parts - Team Camaro Tech
post #1 of 10 (permalink) Old Jul 1st, 15, 08:36 PM Thread Starter
Hey guys, back again needing help with some parts for my 67 RS 327, 210 hp, 2 barrel. Page 102 Aim, 3908966 divorced choke, 3840906 cover choke, page 105, 3908780 spring, 3904249 bracket. This 2 barrel stuff is hard to find. Thx Tom
67 Camaro RS Convertible 327 4 speed
Original unrestored, documented 35k Numbers Matching
69 Camaro SS Coupe X55 350/300hp 4 speed
Fully Restored Numbers Matching
1969 Camaro Z28 Restored
351just is offline
post #2 of 10 (permalink) Old Jul 4th, 15, 11:14 PM Thread Starter
Re: 67 Camaro 210 HP 2 Barrel Carb Parts
Found 67 2 barrel divorced choke, cover, and spring. still need 3908780 bracket.
351just is offline
post #3 of 10 (permalink) Old Jul 5th, 15, 06:57 AM Thread Starter
67 327 2 barrel, Accelerator Bracket, AIM page 105, GM part number 3904249. Thx Tom
ID:	115825   Click image for larger version
ID:	115833   Click image for larger version
351just is offline
post #4 of 10 (permalink) Old Jul 5th, 15, 09:46 AM
Smile Re: 67 Camaro 210 HP 2 Barrel Carb Parts
You can try:
http://www.carbkitsource.com/ or http://www.carburetor-parts.com/
TJS69 is offline
post #5 of 10 (permalink) Old Jul 5th, 15, 10:48 AM
George
My 67 2 barrel did not have a bracket for this. The coil mounting bracket had a hole drilled in it that the spring went into. I always assumed it was the factory setup. Had the car since 1980.
carbuff67rs is offline
post #6 of 10 (permalink) Old Jul 5th, 15, 02:41 PM Thread Starter
Hey Guys, I in boxed Al, his car has one. I have some pics he posted a while ago on another thread, check it out. Al is going to take some additional pics and post them. My mechanic's 327 2 barrel has the same bracket, he is the original owner. Tom, I tried Carb doctor and Mike's, no luck Thx.
ID:	115881   Click image for larger version
ID:	115889   Click image for larger version
351just is offline
post #7 of 10 (permalink) Old Jul 5th, 15, 03:39 PM
Pics of my original 67, 327/2bbl. The bracket in question blends in with the coil mtg. bracket making it appear as 1 unit.
my 67' build thread:
allanjs is online now
post #8 of 10 (permalink) Old Jul 5th, 15, 03:47 PM
George
Interesting. You can see the little hole in the coil bracket right above the adjustment screw head. Thats where my spring has always been connected to. It did touch the manifold a bit using this hole. I never had the little bracket. Btw, whats with the funky looking pcv valve?
post #9 of 10 (permalink) Old Jul 5th, 15, 04:08 PM Thread Starter
Thx again Al for the pics... One think that I find very odd. There were 102,409, 327 2 barrels produced (LF7) in 1967. Why is it so hard to find parts for the 2 barrel setup. Everything being reproduced is for the 4 barrel 327's, 427's and 350's. Examples, divorced choke and cover, accelerator rod, SPRINGS, carb fittings, etc. When you call companies (Ricks, Classic, Heartbeat City, etc) they don't stock any of those items. Does anyone know where I can find the spring bracket pictured? Thx again Tom....
351just is offline
post #10 of 10 (permalink) Old Jul 12th, 15, 08:28 PM Thread Starter
Hey guys, good news. Found the throttle return spring bracket. I installed it yesterday. Check out the pics. Thx for all your help.
ID:	116521   Click image for larger version
351just is offline
