67 camaro 327 coolant temp - Team Camaro Tech
post #1 of 14 (permalink) Old Jul 2nd, 15, 12:22 AM Thread Starter
Romeo
what is the best location for a coolant temperature sensor
-I have idiot lights
-327 motor
-edelbrock intake
-I just think it is to close to the thermostat housing and rad hose
- any pics of installed
tekin is offline
post #2 of 14 (permalink) Old Jul 2nd, 15, 01:05 AM
Dan
Re: 67 camaro 327 coolant temp
My 68 327 has the coolant temp sensor located on the driver side cylinder head (291) toward the front under 1/3 spark plugs. If I remember there is a flat/boss that can be drilled/tapped for a 1/2 npt thread fitting.
68 camaro RS 327/275 THM350 4 wheel disc brake 8.5 10 bolt 3.42 daily driver
icpop is offline
post #3 of 14 (permalink) Old Jul 2nd, 15, 06:31 AM
I've run with the sensor on the intake in the stock location and now on the drivers side head. It didnt make any considerable difference.
Melrose RS is offline
post #4 of 14 (permalink) Old Jul 2nd, 15, 08:12 AM Thread Starter
Romeo
But the rad hose to the top of the pun there is only like a 1/8 of a inch is that ok
tekin is offline
post #5 of 14 (permalink) Old Jul 3rd, 15, 08:03 AM Thread Starter
Romeo
nobody have any input or pics please
tekin is offline
post #6 of 14 (permalink) Old Jul 3rd, 15, 08:49 AM
kevin
if you google your search you can see a lot more pictures
flat tire is offline
post #7 of 14 (permalink) Old Jul 3rd, 15, 11:10 AM
George
If your heads dont have the hole for it then the stock location in the intake is fine. Thats the point where the water gets to the temp to open the t-stat so that seems logical to me (and gm).
carbuff67rs is offline
post #8 of 14 (permalink) Old Jul 3rd, 15, 12:05 PM
DjD
DjD's Avatar
I have had a temp gauge hooked to a sender in both the stock head location and in the manifold and both places read the same. Just because the sender is close to the t-stat housing doesn't mean it will read different. The sender is still before the t-stat and ya maybe before the t-stat opens the water in the head and in the manifold might be slightly different temps but once the t-stat opens the flowing water should even out the temp any point along it path until it gets to the core for cooling.
...Dennis
DjD is offline
post #9 of 14 (permalink) Old Jul 3rd, 15, 12:45 PM
Banned
Chet
Only one is needed and the cylinder head is the best place to take it.
onefiness is offline
post #10 of 14 (permalink) Old Jul 3rd, 15, 06:39 PM Thread Starter
Romeo
Guys I have a edelbrock rpm intake and the port is under the thermostat housing so I am just wondering if it will read incorrectly being so close to the rad hose
tekin is offline
post #11 of 14 (permalink) Old Jul 3rd, 15, 07:01 PM
DjD
DjD's Avatar
Does it look like this... (before and after) before shows the sender. The engine runs 170 and if it gets really hot out climbs to about 180 max. I don't care if the temp number is accurate because it's consistent! If the engine were to over heat I would know it by the gauge movement.
ID:	115585   Click image for larger version
...Dennis
DjD is offline
post #12 of 14 (permalink) Old Jul 3rd, 15, 11:32 PM Thread Starter
Romeo
looks just like that the reason why is I have a gauge in there for engine break in reasons and now I wanna start cleaning up all the wiring so I put the sender back in and if you think it will do the trick then I will install the same way
tekin is offline
post #13 of 14 (permalink) Old Jul 4th, 15, 09:54 AM
George
If youre worried about the rad hose passing over the sender unit closely, dont, its not a problem. It will work just fine.
post #14 of 14 (permalink) Old Jul 4th, 15, 05:13 PM
Steps
Dennis and Melrose above are onto it.....
And if running.. good practice .. both idoit light and temp sensor... run the idoit light on the head....
Reason being if the thermostat is faulty or what ever .. remains closed, the idiot light still comes on.... which stock comes on at 235 degs
Other than that any difference between the locations are a Dennis describes above and for that reason.
Steptoe is offline
