Aluminum radiator - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 17th, 00, 05:07 AM Thread Starter
Was wanting to install an aluminum radiator in my 73RS. I'm looking at Howe and Griffin but am needing suggestions. Don't want to spend a ton of money but want something that will work as advertised. What brands are recommended and how much cooler do they run?
73RS/406/350/10bolt
Hals73RS is offline
post #2 of 11 (permalink) Old Nov 17th, 00, 06:54 AM
I used the Griffin generic radiator, for under $200. The radiator itself made only a slight difference, but when I put a good set of 4th gen fans on it, it worked wonders. Now, at an idle, I can actually see it close the 180 thermostat once and a while!
1992 Firebird 355/Six Speed
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
http://personal.lig.bellsouth.net/~racer383/
Mark W. Winning is offline
post #3 of 11 (permalink) Old Nov 17th, 00, 10:58 AM
Mark,
Do you have the fans thermostatically controlled? If so, what did you use?
Shawn Peterson
1969 Z28, 406SB
http://www.geocities.com/corsican69
Shawn is offline
post #4 of 11 (permalink) Old Nov 17th, 00, 12:46 PM
Why do you want an aluminum radiator? A lot of them don't cool as well as a normal radiator that is desinged correctly.
69er is offline
post #5 of 11 (permalink) Old Nov 17th, 00, 02:53 PM Thread Starter
I have the original style 3 core with a 16" Summit fan and adjustable thermostat. It works OK but at idle in traffic, it can creep to 220. And it makes me a little nervous to see that. I've always heard that aluminum works better and is lighter but would be willing to go with a copper/brass 4 core. It may also be that my fan is just too small.
Hals73RS is offline
post #6 of 11 (permalink) Old Nov 18th, 00, 12:54 PM
May I join in on the chat,
I have a '66 Skylark S/W four core or whatever on my car now. Same stock width. It doesn't have side mounts on it so I have it top bolted and bottom strapped in position.
Whats the chance of it cooling my 496??? And does anybody know if I can get side mounts installed on it by a good radiator shop.
Or am I wasting my time or should I spring for a four core stock wide width radiator or an aftermarket aluminum one??? All comments considered please. pdq67
post #7 of 11 (permalink) Old Nov 20th, 00, 03:44 AM
I disagree with the statement that aluminum will not cool. I have used a few of them and they work great. I think the key is to move enough air accross them to disapate the heat. Going from a three core copper, to a two core aluminum made little difference, but when I added the 4th gen dual fan setup, I lost all my cooling problems. Bottom line is that I do not feel changing to aluminum will cure a problem (unless your copper is plugged), but any difference is minimal. Weight was a big factor in my choice.
Shawn, I hooked them to a switch for now. I am currently shopping for an LT1 setup, so I did not spend the money on a temp switch. Those fans move a lot of air and are well worth the install.
post #8 of 11 (permalink) Old Nov 20th, 00, 06:16 AM
Hey, I just installed a Howe radiator in my car this weekend. It was quite the improvement. I had a 140 thermostat for the summer and my old radiator. Now Im going to have to bump up the temperature of my thermostat because it barely sees 140. After test driving, I could put my hand right on the radiator with out burning it.
I ordered mine from Poske Performance. Their number is 304-428-5000. It cost me $200.49 w/ shipping&handling included.
Tony
obnoxious 67 camaro under construction. TH350/383 stroker w/ aluminum Eldlebroc RPM heads,cam, and carb.
OBNXUS67 is offline
post #9 of 11 (permalink) Old Nov 21st, 00, 11:55 AM
Carl
Mark,
How did you mount the 4th gen fan setup? I took some measurements a few weeks ago from one and could not come up with a good way to mount it due to the fans and shroud being pretty wide (26") in comparison to the 23" 1st gen core.
Carl
Click here to see see my car and hear 5-speeds. http://www.geocities.com/casanoc
CarlC is offline
post #10 of 11 (permalink) Old Nov 21st, 00, 03:20 PM
i had a heating problem too ,with the 2 core 21",and a broken shroud.(stock rad.) i installed a 3core,21",and a new shroud (brass/copper--stock repro.)...now runs around 160 - 210... depending on if i'am flat footing it or not.
406ci
mech.fan
My68Camaro
Doug G.
68 Camaro
406 ci.
[This message has been edited by DOUG G (edited 11-21-2000).]
post #11 of 11 (permalink) Old Nov 22nd, 00, 02:13 AM
Carl, I put mine in a 3rd gen, they must be a bit wider. There is not a lot of fat to trim on those fans. I will have to look at them tonight. You may get away with trimming the edges.
