vaccum. - Team Camaro Tech
post #1 of 10 (permalink) Old Dec 27th, 04, 08:28 AM Thread Starter
Smile
Hei.
What is the best place too hook up the vaccum hose from the brakes.On my carburator or on the Edelbrock RPM intake.There is a plugg right behind the carb on the intake.Howe is it made original.I have a bit lumpy idel.
Johan is offline
post #2 of 10 (permalink) Old Dec 27th, 04, 09:47 AM
James
Send a message via Yahoo to james7773
Id put it on your intake. Eldelbrock should sell the adapter for the intsalation.
You may run inot low vacume from your cam, IMO, it depends on what cam you have. Ive heard of people putitng vacume bottles to help.
My 67 RS 327...its a work in progress.
james7773 is offline
post #3 of 10 (permalink) Old Dec 27th, 04, 09:50 AM
the "stock" way of doing it is to hook the power brakes up to the big port on the base of the carb, but if you have a carb that isn't a q-het, then the intake is probably the easiest.
you don't plan sincerity.
novaderrik is offline
post #4 of 10 (permalink) Old Dec 27th, 04, 02:16 PM
Your original power brake line should hook right into the power brake vac port on the back of the edelbrock carb. Every edelbrock carb I have done, including 2 that I own now, are this way.
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #5 of 10 (permalink) Old Dec 27th, 04, 02:55 PM
never knew that Travis, but so it is. My 1407 has a port on the front I use with my pcv, and a plugged port on the back.
post #6 of 10 (permalink) Old Dec 27th, 04, 06:33 PM
I did things a bit different. I pluged the power brakes into the manifold tap and the PCV into the rear port on my Holley. Reason is that the Holley's rear port diverts equally to both planes of the manifold. The manifold tap does not. I wanted my blow-by gases to be evenly distributed. I'm not sure how the Edelbrock carb is configured though. I used another manifold vacuum port off the front of the carb for vacuum advance.
dnult is offline
post #7 of 10 (permalink) Old Dec 28th, 04, 06:46 AM Thread Starter
Thanks Guys.
I will put it on the base of the carb.
Johan is offline
post #8 of 10 (permalink) Old Dec 28th, 04, 09:56 AM
Kyle
It really doesnt matter which one you use either the base of the carb if you have it or the intake port behind the carb they will both do the job fine (depending on your cam providing you with enough vacuum to run the brakes). But I have never seen a difference between the two connections. If you do not have enough vacuum to run the brakes neither port will change that.
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4 WHEEL DISK BRAKES,
4:11 POSI
BLUE W/WHITE STRIPES
GreyShadows is offline
post #9 of 10 (permalink) Old Dec 28th, 04, 04:31 PM
JohnZ's Avatar
All factory power brake installations used a fitting in the top of the intake, just behind the carburetor; all V-8's, all carbs. [img]graemlins/thumbsup.gif[/img]
JohnZ
CRG
JohnZ is offline
post #10 of 10 (permalink) Old Dec 29th, 04, 08:32 AM Thread Starter
Thanks again everybody.
Johan is offline
