89 Octane gas with 9.6~9.75 compression - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 14th, 03, 12:46 PM Thread Starter
Hello all,
I was just wondering... If build my 327 with flat top 4 vr pistons and Vortec heads and about 32-34 deg. of total ignition timing, as I planned, will it be able to tolerate the mid-grade gas or will I have to run 91 octane or up.
If the engine can't tolerate the mid grade gas, no big deal. I will certainly run the 91 octane stuff... any thoughts?
- Mark P.
Granny's 69 is offline
post #2 of 5 (permalink) Old Oct 14th, 03, 03:28 PM
Matt Jones
I'm running a true 9.6:1 and run 89 octane with 32* total timing. This will also vary with the load place on the engine...a car will 4.11:1 gears will ping less than a car with 3.08's.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #3 of 5 (permalink) Old Oct 14th, 03, 03:39 PM
355 cid 9.6:1 on 87 octane, 432hp @ 5850rpm w/ 34* total.
chicane67 is offline
post #4 of 5 (permalink) Old Oct 19th, 03, 11:02 PM
Depends on the cam also
jimfulco is offline
post #5 of 5 (permalink) Old Oct 20th, 03, 05:38 AM
Paul
I run my 10.65:1, aluminum headed, L82 cam, 383 on 87, 89 or 91. It doesn't ping on 87, even in summer.
My LM1 after being rebuilt pinged a whole lot more than my 383 and that has pretty low compression(8.5:1) but I'm running that XE262 cam. I can't remember how far the pistons were in the hole, but it was a ways so my quench is way over .040.
The quench on the 383 is pretty tight, like .032-.035. The guy who built my engine said that the tight quench, L82 cam and aluminum heads would allow me to run 87. I didn't believe him, so I ran 91 but eventually I tried 87 and it works fine.
Best of 1.55 - [email protected]
paulm is offline
