Does anyone know if an 8.5 from a 78 RS will go into a 68? - Team Camaro Tech
post #1 of 8 (permalink) Old Jul 25th, 01, 11:32 AM Thread Starter
I'm just wondering because my 68 has an open 8.2 rear-end with the little 2.73's and I bought a 78 RS camaro that has an 8.5 rear-end. I have two questions:
1)Will the 8.5 swap right in with-out any axle shortening or anything like that?
2)What is the gear ratio on the 78 camaro's rear-end?
Thanks,
Donnie
1968camaro123 is offline
post #2 of 8 (permalink) Old Jul 25th, 01, 11:51 AM Thread Starter
Oh, I have mono-leaf springs. I don't know if that makes a difference.
Donnie
post #3 of 8 (permalink) Old Jul 25th, 01, 02:51 PM
Freddie
I don't think it is a simple bolt in. The '78 is a little wider, but I don't think the mounts are the same. The '78 probably has 2.73s in it too. I don't think you would gain much.
'69 RS/SS396 pro street
427/4spd/9"
Byars Performance
High Performance Drive Train Parts And Service
www.lubedealer.com/biggearhead
big gear head is offline
post #4 of 8 (permalink) Old Jul 25th, 01, 05:20 PM Thread Starter
Okay, thanks big gear head but aren't the 8.5's quite a bit stronger than the 8.2?
Donnie
post #5 of 8 (permalink) Old Jul 26th, 01, 02:14 PM
Freddie
Yes they are. I just meant you wouldn't gain anything in the gear ratio. If you want to spend the money on gears and a posi then the 8.5 would be the one to build, but I don't think this one will fit your car.
427/4spd/9"
Byars Performance
post #6 of 8 (permalink) Old Jul 26th, 01, 05:05 PM
Brad
I think that 71-74 nova 8.5's are a direct bolt in. You can use the posi carrier out of any 8.5. You might want to do a search to make sure that my year models are correct, but I think that I am right.
Back me up, guys
Brad
68, 327, TH350 (assembly in process)
Godspeed #3
Brad74 is offline
post #7 of 8 (permalink) Old Jul 26th, 01, 07:13 PM Thread Starter
Thumbs up
Okay, thanks alot guys.
Donnie
post #8 of 8 (permalink) Old Jul 27th, 01, 06:51 PM
On the Nova the years that will work goes up to the 76 model. Crap, I measured the rear end of my 79 Z28 a couple of days ago but I forgot what the measurement was. Your 78 rear end is to wide though, it will need to be narrowed to work.
[This message has been edited by zzre (edited 07-27-2001).]
zzre is offline
