victor jr on SBC 69 camaro - cowl hood/linkage - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 8th, 15, 08:12 PM Thread Starter
Aaron
anyone using a Vic Jr on their 69?
curious to know if the stock carb linkage works without modification - and if the height works with the Cowl hood (car is a z so i'd be moving from the Z28 intake)
thanks
69z28boy is offline
post #2 of 5 (permalink) Old Jul 8th, 15, 09:04 PM
Steve69SS396's Avatar
Re: victor jr on SBC 69 camaro - cowl hood/linkage
Fits just fine. I do have an adjustable upper rod on my linkage. The rest of the linkage is stock.
Steve69SS396 is offline
post #3 of 5 (permalink) Old Jul 9th, 15, 06:43 AM Thread Starter
Aaron
Cool - your sig says dart single plane - is that the same as the Vic Jr in terms of height or did you have the vic jr on?
69z28boy is offline
post #4 of 5 (permalink) Old Jul 9th, 15, 08:12 AM
The picture is of my old 357 with a Victor Jr.
post #5 of 5 (permalink) Old Jul 10th, 15, 08:12 AM
Yes, the stock throttle linkage works perfect on a Victor Jr. Here is a pic of mine (a little blurry). I made a custom coil bracket to put the coil in the stock location as well. I'm running a 3.5 inch filter element and it clears the cowl hood just fine.
Neil B is offline
