327 cutting out - Team Camaro Tech
post #1 of 12 (permalink) Old Jul 9th, 15, 06:55 PM Thread Starter
327 cutting out
I took my 69 out for a drive this evening and the motor would act as if it was going to die occasionally. It didn't matter if I was going slow or fast it would start to die and I could tap the gas and it would take back off. It idles fine and runs smooth other than this problem. I have a 600 CFM Holley which I've had about 4 years and never has given any trouble and an 80 GPH Holley fuel pump which is less than a year old. Plugs were replaced about three years ago and a Summit inline fuel filter put in about a year ago. Stock points distributor which hasn't been touched since I bought the car 5 years ago. Plug wires haven't been changed either. Would appreciate any suggestions on where to start.
69bowty is offline
post #2 of 12 (permalink) Old Jul 9th, 15, 07:28 PM
Apprentice
mitchell
Re: 327 cutting out
do you have dwell meter to check the point gap?then check the timing,is this the first time you had it out this summer?
mls68z28 is offline
post #3 of 12 (permalink) Old Jul 9th, 15, 09:23 PM
Smile Re: 327 cutting out
You might want to change that fuel filter. It only takes one bad tank of gas to plug a filter, even if it is 2 day's old !
TJS69 is offline
post #4 of 12 (permalink) Old Jul 9th, 15, 11:42 PM
mike
Re: 327 cutting out
I would check the points first as suggested. Also could not hurt to check the float levels.
bigblockragtop is offline
post #5 of 12 (permalink) Old Jul 10th, 15, 12:26 AM
Doug
Re: 327 cutting out
Have you ever considered changing from points to electronic ignition. http://www.summitracing.com/parts/cr...t/model/camaro or here is the points and condenser kit. http://www.summitracing.com/parts/sm...make/chevrolet. I would start with changing the points, condenser, rotor button, and cap. Plug wires and spark plugs. Also the fuel filter. If you still have a problem after tuning it up the carburetor will probably need a needle and seat. Just get a Holley rebuild kit and take the carburetor a part to clean it then start replacing needle and seat, power valve, pump diaphragm and gaskets.
Cdminter55 is offline
post #6 of 12 (permalink) Old Jul 10th, 15, 02:09 AM
Joe
Re: 327 cutting out
I ditched my points for an electronic conversion and it works great. In 2015, why waste any time messing with breaker points still?? I used a pertronix, but that Crane setup in the link above looks really good too. I like that it includes a rev limiter and plus its substantially less expen$ive than the pertronix
The important thing here is that you ask me what kind of car I've got. "I've got a BITCHIN' CAMARO"
'68 350 4 speed
kookykrispy is offline
post #7 of 12 (permalink) Old Jul 10th, 15, 04:08 AM Thread Starter
Re: 327 cutting out
Thanks everyone for the info. This isn't the first time I've had it out, been driving it quite a bit on the weekends this summer but it's the first time it's acted up.
69bowty is offline
post #8 of 12 (permalink) Old Jul 10th, 15, 09:00 AM
Joe
Re: 327 cutting out
another thought is you may have crud in the gas tank, clogging up the pickup or something. If you do the above suggestions and it still has problems, you may need to drop the tank and see if it needs cleaning
'68 350 4 speed
post #9 of 12 (permalink) Old Jul 10th, 15, 02:52 PM
mike
Re: 327 cutting out
Yea today.s gas does not go much beyond a few months without any stabilizers. You can store the car for the winter with Av gas, it does not go bad.
post #10 of 12 (permalink) Old Jul 12th, 15, 10:46 AM Thread Starter
Re: 327 cutting out
I'm considering going with the Crane XR1. Should I also replace the coil?
69bowty is offline
post #11 of 12 (permalink) Old Jul 12th, 15, 03:57 PM
William
Re: 327 cutting out
This might sound like a dumb response but any chance your cables are loose on the battery. Certainly worth checking before you tear into other more complex possibilities. How do I know? Be there.
brumbach is offline
post #12 of 12 (permalink) Old Jul 12th, 15, 06:30 PM Thread Starter
Re: 327 cutting out
Thanks brumbach. I had just put in a new battery but the cables are tight. Hadn't thought about that.
69bowty is offline
