LS swap 69 - Team Camaro Tech
post #1 of 13 (permalink) Old Jul 10th, 15, 04:27 AM Thread Starter
allen
siettas81's Avatar
LS swap 69
ok fellas i would like to start getting parts around for a LS swap i would like to do 6.0 just because seems like everyone does the 5.3 but 5.3 is not out of the question i will do either !
few questions
what year / model engine 6.0 or 5.3 should i look for
what trans should i run / currently the car has turbo350 auto
the car isn't a drag car, just going to be a cruiser
thanks in advance educate me i will appreciate it !!!
siettas81 is offline
post #2 of 13 (permalink) Old Jul 10th, 15, 05:05 AM
Re: LS swap 69
I'm old school, so I have no opinion on which to get, but that is a nice looking car!
buenymayor is online now
post #3 of 13 (permalink) Old Jul 10th, 15, 05:10 AM
Re: LS swap 69
5.3's are cheaper and were (still are) used in 1/2T trucks and SUV's
6.0's were used in 3/4-1T trucks
For what you're looking to do, a 5.3 would be fine and perform well or even better with a few bolt-ons.
I used the TCI flexplate to keep my 350TH, but you could get the whole motor/trans combo for your swap to get the OD trans.
Some places will offer (at a cost) everything needed to do the swap (gas pedal if a DBW, computer, ETC) So you'll need to shop around some if keeping the EFI.
You will also need motor swap mounts and such, there may be some fab'ing depending on what you want/need.
68 Camaro~LSx ~all motor
post #4 of 13 (permalink) Old Jul 10th, 15, 05:45 AM
Banned
Chet
Re: LS swap 69
Key words why I wouldn't do the LS swap. "just because seems like everyone does" and "just going to be a cruiser". An awful lot of work and money just to be like everyone else and just to cruise around. I have gone on record myself saying that if my engine ever went south and was unrepairable, I would go LS. Now, I'm not so sure. Heads and EFI and very sophisticated computer controls/electronics are what makes the LS. You can put better heads on your current engine and fuel inject it. I'm just not sold on the LS as much as I was anymore. That's me, it's your car so if you want an LS put an LS in it.
onefiness is offline
post #5 of 13 (permalink) Old Jul 10th, 15, 06:49 AM
Re: LS swap 69
EFI is nice IF you have the parts and know-how.....me I like carbs and can tune myself
As for the costs....it's all relative.
If I was to do another SBC in the same HP range and bought intake to pan, I'd be at near the same costs.
If I rebuilt what I had and added the better heads I needed, I may be in it for about $1500 less.
If I just freshened up what I had, I may be in it for about $2500ish
My old 406ci SBC was getting tired, and was a little rough on the street with the 25X/26X solid roller. This 364" SBE with the same compression and hydraulic roller (23X/24X) is much tamer on the street, runs cooler, and has already been as fast as the old 406" (well .02 slower and still tuning) but has more in it yet
It's your car and your $$$....have fun
post #6 of 13 (permalink) Old Jul 10th, 15, 07:11 AM
Brent
67Rally's Avatar
Re: LS swap 69
If you are going with an iron block, I would look for an LQ9 (6.0 with higher compression) first, then and LQ4 (6.0 with lower compression), then a 5.3 last.
If you want an aluminum block, LS2 (essentially an aluminum block version of an LQ9), also plenty of aluminum 5.3's out there to choose from newer trucks.
67Rally is offline
post #7 of 13 (permalink) Old Jul 10th, 15, 07:14 AM
Vega$69's Avatar
Re: LS swap 69
As I've stated before the Engine whether a takeout LS1, 5.3 or LS2 is the cheapest part of the swap.
It's everything from the swap plates, to the fuel and cooling system upgrades that will add approx $5k to the swap costs.
I would not spend the time or money on a 5.3 unless I was going to Boost it or Hit it.
Also need to decide if you want Alum or Iron block. Auto or Manual?
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #8 of 13 (permalink) Old Jul 10th, 15, 07:16 AM
Brent
67Rally's Avatar
Re: LS swap 69
Doug, your setup looks a lot like mine. An EFI system is pretty simple to put together for that. I went with an Edelbrock Vic Jr, Edelbrock fuel rails, and a 4 barrel throttle body with a traditional air cleaner on top. I added an aftermarket harness with a GM computer and had it tuned locally. I'm not saying it's cheap, but I see you keep mentioning how you would only do EFI if you already had the parts. But you also like carbs, and I don't, so that makes a big difference!
67Rally is offline
post #9 of 13 (permalink) Old Jul 10th, 15, 07:22 AM
Vega$69's Avatar
Re: LS swap 69
I used to be 100% old school carb guy too. But once I got into EFI I was hooked.
I know you have the skills and knowledge that if you gave it a shot you'd come up to speed quickly.
Once you go EFI you'll never go back.
Vega$69 is offline
post #10 of 13 (permalink) Old Jul 10th, 15, 08:19 AM
Re: LS swap 69
IF I was to go EFI, it would be something like a FAST 2.0 system. I would not keep the stock EFI, but that's just me.
A lot of the aftermarket systems are only good to 500hp or so, and I hate being limited
EFI = Voodoo
post #11 of 13 (permalink) Old Jul 10th, 15, 08:38 AM
Vega$69's Avatar
Re: LS swap 69
EFI = Voodoo
The stock EFI with stock fuel rail and bigger injectors is good for up to 1000 hp or more.
My LS7 was about 635 and my LS1 Vette with the Maggie on it was about 650
Vega$69 is offline
post #12 of 13 (permalink) Old Jul 10th, 15, 06:25 PM
Re: LS swap 69
Sorry....I meant in aftermarket stuff
post #13 of 13 (permalink) Old Jul 13th, 15, 09:41 AM Thread Starter
allen
siettas81's Avatar
Re: LS swap 69
thanks all im going o keep eye out for 5.3 with 2wd trans and start collecting parts
