Intake manifold is 'stuck' - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 17th, 04, 03:58 PM Thread Starter
I'm running an aluminum Edelbrock Performer intake manifold on my 305. I think that I have a vacuum leak (and an oil leak and a little water leak) thanks to my intake as it is, so today I bought new gaskets & broke it down to re-seal the manifold.
All bolts are out, and there are no obstacles. EXCEPT...it will not come loose. I've tried a hammer & a block of wood with no results. Does anyone else have any tips for removing a stuck manifold?
Thanks!!
1982 Camaro, 305, 4bbl Q-Jet
Scott Reeves HSV is offline
post #2 of 9 (permalink) Old Apr 17th, 04, 04:16 PM
Bill
Big screwdriver or pry bar between the manifold and head. Once it gets started it will come right off.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is online now
post #3 of 9 (permalink) Old Apr 17th, 04, 05:14 PM
Not to be a wise guy or anything, but, did you remove the distributor?
BPOS is offline
post #4 of 9 (permalink) Old Apr 17th, 04, 06:33 PM Thread Starter
Talking
[img]smile.gif[/img] Yeah...the distributor is out of the car. That would have been funny.
I'll pry away. I thought of the screwdriver or pry-bar technique, but was reluctant without someone seconding that motion. I appreciate it!
Now, I hope that new gaskets will solve my problems.
post #5 of 9 (permalink) Old Apr 18th, 04, 06:14 PM
yea you have to get real crazy sometimes with intake manifolds and rock em back and forth with some kinda bar.
<a href="http://atlas.walagata.com/w/artfuldodgerv2/AAAA0017.JPG" target="_blank">68 RS</a> : 383, performer RPM heads, Victor Jr. Intake, Holley 780 DP, Crower 224HR232, 700R4 trans, 4.56:1 10 bolt. - driven every day
YouthTronix is offline
post #6 of 9 (permalink) Old Apr 18th, 04, 08:56 PM
Sounds like the first cam swap I ever did. Got everything off the top of the motor, and the cam would not come out. I pried on it, cussed it, etc...finally called a local shop and asked what the heck was going on. He asked "did you remove the fuel pump?" Well, uhhh, no [img]graemlins/clonk.gif[/img]
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #7 of 9 (permalink) Old Apr 20th, 04, 01:54 PM
J
I usually leave the water neck on and use a broom handle to pry it off. I didnt want to use a screwdriver to pry it off the head for fear of damaging the mating surface. Overkill, maybe, but it gives me peace of mind.
magisnyc is offline
post #8 of 9 (permalink) Old Apr 20th, 04, 02:34 PM
Steven
Sometimes you need to remove the valve covers .... did you ?
sdtsdt is offline
post #9 of 9 (permalink) Old Apr 21st, 04, 10:11 AM
Bill
That's a good tip!
WildBillyT is offline
