Rocker stud cut - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 25th, 04, 10:35 AM Thread Starter
I have a 68 Camaro 327. Completely rebuilt engine, valves and all. Did not replace rocker studs. However I have replaced(3)rocker studs since the rebuild that had cuts in the side of them causing the rocker arm to sit sideways slightly and eventually would come off of the valve. Are the studs just worn from age since they were not replaced and I just didn't notice it on the rebuild, or is there something I am missing?? I have replaced the(3)with the screw in studs and that fixes the problem, just not sure what created the problem. Have not run into this before. But a definate cut in the side of the stud.
Thanks for any ideas!
oldcarman49er is offline
post #2 of 9 (permalink) Old Apr 25th, 04, 12:52 PM
Bill
old, (Name ??)
Take a look at the oblong holes where the pushrods pass through the cylinder head. If your heads have the stock, pressed in, rocker studs, then the pushrods should be a pretty "snug" fit in the holes in the head. That is all that guides them and keeps them from moving to the side. If the holes are worn badly, you will have to remove the heads and have screw in studs and guide plates installed. The other thing to look at is the tips of the valves. If they are not perfectly square, they can cause the same problem.
Hope this helps,
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 9 (permalink) Old Apr 25th, 04, 03:50 PM Thread Starter
Angry
Thanks Bill: I will check those areas. Makes sense and doesn't sound to extensive a repair even if I have to pull the heads to fix. Just ashame that the machine shop didn't see a problem.
Oh, the name ? I love old cars and I'm a San Fransico 49er's fan. So I put the 2 together!
Makes oldcarman49er!
post #4 of 9 (permalink) Old Apr 25th, 04, 04:54 PM
i think he wants to know your name when you are not on an internet message board- you know,what Ma and Pa called you when you were young...
you don't plan sincerity.
novaderrik is offline
post #5 of 9 (permalink) Old Apr 25th, 04, 05:38 PM
Angry
Yes,
Bill likes to call us by our given names! It's a thing with him and I respect him for it b/c I have razzed him about it before..
Paul, (aka, pdq67)
post #6 of 9 (permalink) Old Apr 25th, 04, 05:55 PM
I bet your rocker arm geometry is out of wack. I had an early 327 that the lifter bores were not correct. The thing would saw rocker arms in two until I put a set of heads on with guide plates that I could adjust. After I got everything right no more problems.
oger is offline
post #7 of 9 (permalink) Old Apr 26th, 04, 05:06 PM Thread Starter
Unhappy
Bill:
The oblong hole for the pushrod seems to be snug like the rest of them. The end of the valve looks square from a visual. The only thing that looks slightly out of alignment is the rocker stud itself. But just slightly. It doesn't look perfectly square to the head, but only a few degrees at most! This could be causing the problem. I have built many small blocks, and this is the first time I have run into this problem before. Oh yeah, Bill, my name is Kim! My parents were on drugs when I was born!!
Thanks for all imput!!
post #8 of 9 (permalink) Old Apr 27th, 04, 08:56 AM
i had the same problem and traced it back to valve spring coil bind,also lack of valve guide to retainer clearance will cause this.
Eric
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
SLEEPER 86 is offline
post #9 of 9 (permalink) Old Apr 28th, 04, 05:22 PM
67 Camaros Rock
Joe Harrison's Avatar
did you go with a higher lift cam? If so the rockers you have may not be long slot rockers. To much lift and kicking the rocker to the side?
Are the studs strait? You said you replaced with screw in studs, I would think you have pressed in? Could be bent studs or bending studs or loose pressed in studs. If all studs are drilled were they drilled strait/ I have seen a nice set of heads ruined once by a friend drilling his and not paying attention to his work.
Just some thoughts hope they might help.
Joe.
BTW:
The name thing about Bill, never knew that, but he must like me
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
