Plug wire recommendation - Team Camaro Tech
post #1 of 22 (permalink) Old Jul 17th, 15, 07:28 PM Thread Starter
Just recently installed a Crane Cams XR-1 point conversion module, Crane coil, new AC Delco distributor cap and rotor button. Any suggestions on what type of plug wires to buy?
69bowty is offline
post #2 of 22 (permalink) Old Jul 17th, 15, 07:55 PM
Vega$69's Avatar
Re: Plug wire recommendation
I like Taylor Spiral Wound
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 22 (permalink) Old Jul 17th, 15, 08:04 PM
ZZ_430's Avatar
MSD 8.5 for me.
http://www.summitracing.com/parts/ms...FQoLaQod0QICNg
I Always get the cut to length ones.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #4 of 22 (permalink) Old Jul 17th, 15, 08:05 PM
Randy
Firecore or Moroso Ultra 40s
1967 camaro, 327, 9.7 CR, comp cam xs274solid, vortec cylinder heads, edelbrock vortec performer rpm, 750 annular carb, HVH 2" spacer, msd pro billet w/6A box, turbo 350 trans, 3500 stall, 4:10 gears, caltracs suspension, m/t drag radials.
rkmjbad67 is offline
post #5 of 22 (permalink) Old Jul 18th, 15, 05:29 AM
Bruce
Taylor Spiral. . . .many colors to choose from as well. I have 2 of my 69's that have Taylors for more than 10 years and all is fine. One has black the other orange.
The Camaro Guy is offline
post #6 of 22 (permalink) Old Jul 18th, 15, 06:30 AM
DT
Donny
DT's Avatar
x2
DT is offline
post #7 of 22 (permalink) Old Jul 18th, 15, 06:49 AM
Harry
dawg's Avatar
Moroso Ultra 40 Race Ignition Wire Sets
I tried all the others and these hold up very well.
434 stroker
US Navy retired
dawg is offline
post #8 of 22 (permalink) Old Jul 18th, 15, 10:21 AM
kevin
taylor for me
flat tire is offline
post #9 of 22 (permalink) Old Jul 18th, 15, 11:22 AM Thread Starter
Thanks for the replies. One more question. The Crane PS40 coil I just installed came with a ballast resistor I'm going to use and get rid of the resistor wire I have cause it looks like s_ _ _. Someone spliced a wire to it and used a wire nut to join the two and I want to get rid of it. What gauge wire should I use to hook up the power supply to the resistor? Can I hook up the wire to somewhere else besides the ignition switch?
Thanks again!
69bowty is offline
post #10 of 22 (permalink) Old Jul 18th, 15, 02:31 PM
Morgan
The crane unit needs the resistor wire that came on your car, either fix it or use their ugly mopar type resistor, a full 12 volts will burn up the crane, the pertronix 111 uses a full 12 volts
69 Copo 9560 ZL-1 automatic [email protected], 1.95 on f70-14 polyglas F.AS.T. Race June 2016
69 Copo 9560 ZL-1 4spd [email protected] 1.93 60ft on F70/14
PSMCDR 2014
71LS6 vette [email protected] PSMCDR 2012 SOLD
1971ls6 is offline
post #11 of 22 (permalink) Old Jul 18th, 15, 03:32 PM
Doug
I like the Taylor Spiro-Pro Race-Fit Spark plug wires. http://www.summitracing.com/parts/ta...make/chevrolet. I used to use Accel or Moroso Blue Max spark plug wires. The engine had a little shake at idle with these wires. After installing the Taylor wires with the 135 degree ends the engine idled smooth. I always had a problem with the headers burning the boots on Accel wires cause a misfire. The Taylor wires are of good quality because they last unless a boot gets too close to a header. I had a set on my 454 engine for about 5 years and when I was replacing them a friend asked if he could have the old set for his truck. He said they were good wires.
Cdminter55 is offline
post #12 of 22 (permalink) Old Jul 18th, 15, 09:49 PM
Chris
I have used Summit branded 8mm wires for years and never had a problem.
http://www.summitracing.com/parts/sum-868836r
shoddy_F-body is offline
post #13 of 22 (permalink) Old Jul 19th, 15, 02:53 AM
Larry
You need to come off the ignition switch "run" wire through the resistor to the "+" terminal on the coil. The "start" wire from the key switch bypasses the resistor and goes straight to the "+" terminal of the coil. Double check the instructions that came with the Crane module though. 14 gauge wire is plenty big enough.
L Holmes is offline
post #14 of 22 (permalink) Old Jul 19th, 15, 02:21 PM
Tom Anderson
MSD for me summit racing but to each his own
socal_tom is offline
post #15 of 22 (permalink) Old Jul 19th, 15, 09:25 PM
Sean
I really like and have had great luck with MSD super conductor wires, and the similar ones Moroso sells. They both work well and are very durable.
It's funny lots of guys recommend the Taylor's, I have owned a few sets over the years and had friends that had them, and they are the one brand I would avoid.
Sean
Franklin D. Roosevelt
68rs406 is offline
