Lokar Throttle Cables - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 2nd, 03, 11:06 AM Thread Starter
I was unsure if this was the correct forum to ask this question but here it goes.
Has anyone converted the stock first gen Camaro throttle linkage to a Lokar cable system? I have the cable and required bracket but do know the best nethod for attaching the cable end to the gas pedal for proper operation.
Any help would greatly appreciated.
Thanks,
Larry
69 Camaro Sallee Chev. 630hp/502, Martz sub-frame, Tremec, Moser 12 bolt.
2nd 69 Camaro Soon to be a Lewis Racing 540ci Motor currently being built.
C5 Corvette
2004 MDX
2001 Honda Accord
1999 GMC Truck
LarryC5 is offline
post #2 of 2 (permalink) Old Aug 3rd, 03, 07:46 AM
TOM
Cool
What I did was to bend the top of the shaft,were the old cable went,so that the new Lokar cable fit through stright on,that is so the Lokar connector has the gas shaft facing at it,and then put a carter pin through,going horizontaly.Also keep the cable straight,and short,and lubed.
TOMSTV is offline
