Rough Idle - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 21st, 15, 07:45 PM Thread Starter
Rough Idle
I just recently installed a Crane XR1 points conversion module with a PS40 crane coil, new cap and rotor. I've noticed the motor idles a little rough but when I increase the RPM's it smooth's out fine and runs well. Could this just be a matter of resetting the timing to fix it?
69bowty is offline
post #2 of 3 (permalink) Old Jul 21st, 15, 07:50 PM
69-Pace's Avatar
Re: Rough Idle
Sounds like the best place to start. I would also check your idle mixture settings while your at it.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 3 (permalink) Old Jul 22nd, 15, 11:00 AM
George
Gbauer's Avatar
Re: Rough Idle
Could be a vacuum leak...
Or a loose plug wire.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
