So... anyone have a base for a Holley 8007 hanging around? - Team Camaro Tech
post #1 of 17 (permalink) Old Jul 22nd, 15, 11:00 AM Thread Starter
George
Gbauer's Avatar
Seriously, though, anyone have a base available?
On a brighter note: I found my vacuum leak!
Might be an excuse to go to 500 CFM as that's where this engine is heading anyway. I'm about out of carb already and I haven't done the head work yet.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #2 of 17 (permalink) Old Jul 22nd, 15, 12:27 PM
Re: So... anyone have a base for a Holley 8007 hanging around?
JB Weld
Most any base plate will work.
post #3 of 17 (permalink) Old Jul 22nd, 15, 12:39 PM Thread Starter
George
Gbauer's Avatar
Originally Posted by Everett#2390 View Post
JB Weld
A lot of people have said JB Weld. At first I thought it was a joke. Now I'm starting to wonder if people aren't serious...
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #4 of 17 (permalink) Old Jul 22nd, 15, 01:12 PM
kevin
maybe it is just me, but I never had no success with jb weld
flat tire is offline
post #5 of 17 (permalink) Old Jul 22nd, 15, 01:27 PM
George
I had the same issue with the old 600cfm gm numbered carb from my old corvette. I guess I could have used the baseplate from any old 600 but I think the pcv was in a weird spot compared to generic 600s. I couldnt get any kind of jb weld stuff to work. Ended up with a newer carb and it ran better anyway.
carbuff67rs is offline
post #6 of 17 (permalink) Old Jul 22nd, 15, 02:04 PM
JB Weld is great in some applications but not where heat is a factor, the heat causes cured epoxies to turn soft and fail.
NH69Z28RS is offline
post #7 of 17 (permalink) Old Jul 22nd, 15, 02:39 PM
Bentley
It's aluminum. TIG it up and run a file across the bottom.
ko-lek-tor is offline
post #8 of 17 (permalink) Old Jul 22nd, 15, 07:53 PM
Ya George, I have one. PM sent...Jb
Beat it to Fit, Paint it to Match!
Johnny B is offline
post #9 of 17 (permalink) Old Jul 23rd, 15, 07:15 AM
Like painting a car, your success with epoxy (JB Weld) will depend upon preparation of the part. There is also the problem with the epoxy clogging or completely closing any small machined passages. If properly prepped and there are no passageways; then the epoxy will hold the part together in tension as well as the base metal. It will not support shear however, so it won't tolerate much in terms of side loading (over torquing the base plate).
Big Dave
Larger Dave is offline
post #10 of 17 (permalink) Old Jul 23rd, 15, 07:42 AM
Eric
JB weld will not hold that.
You might be able to buy a new base directly from Holley. Call the custom shop and ask.
Carburetor Rebuild & Restoration
Engine & Driveline Parts & Services
Vintage Musclecar is offline
post #11 of 17 (permalink) Old Jul 23rd, 15, 08:37 PM Thread Starter
George
Gbauer's Avatar
So I'm starting to consider just going up a size or two.
I've felt the 390 wasn't enough for the engine:
250
Offy intake.
390 CFM carb
Langdon split headers.
2.5" single exhaust
Flowmaster 44 muffler.
This winter I'll pull the head, add in oversized valves and lump ports (and a polish) and a cam.
So.... 450 CFM? Bigger? How much?
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #12 of 17 (permalink) Old Jul 23rd, 15, 10:01 PM
Roger
rogerh's Avatar
Before putting another carb on that intake I would make sure the intake is perfectly flat.
Roger
rogerh is offline
post #13 of 17 (permalink) Old Jul 23rd, 15, 11:20 PM
ZZ_430's Avatar
250
Offy intake.
390 CFM carb
2.5" single exhaust
570 Street Avenger, great carb for a small motor! http://www.summitracing.com/parts/hly-0-80570/overview/
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #14 of 17 (permalink) Old Jul 23rd, 15, 11:29 PM
Doug
You ought to try a 500 cfm Holley. Back in the day I knew a couple of guys that had Plymouth Dusters with the slant 6 engine. They would change intake manifolds and carburetors and add an aftermarket camshaft and Hooker headers. I believe Offy's were the manifolds they used too. The Dusters gave many guys with a stock 327 engine a surprise.
Cdminter55 is offline
post #15 of 17 (permalink) Old Jul 24th, 15, 08:52 AM Thread Starter
George
Gbauer's Avatar
Called Holley: getting a new base for $88 shipped.
I'll wait on more air and fuel until I go efi.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
