TPI 1989 IROC-Z WITH 350 -CODES 33 AND 36 - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 10th, 03, 05:46 AM Thread Starter
Red face
HEY CAMARO BROS. WHAT SHOULD I DO IF I REPLACED THE M.A.F.SENSOR. AND RELAY. NOT SURE IF I CHANGED THE RIGHT RELAY CAN ANY ONE TELL ME IF I CHANGED THE RIGHT RELAY FOR THE BURN OF. I CHANGED THE ONE IN THE MIDDLE THERE ARE THREE ON THE DRIVERS SIDE NEAR THE FIRE WALL . AGAIN CODE 33AND 36. I HOPE ITS NOT THE ECM. THE CHECK ENGINE LIGHT IS NOT COMMING ON RIGHT [img]graemlins/beers.gif[/img] NOW, I TOOK IT TO A LOCAL SHOP THEY FOUND NOTHING. ANY ADVICE IS APPRECIATED. THANKS
P.S.
LOVE CAMAROS DON'T LIKE CHUMPSTANGS .
MR. LISTO
MR. LISTO is offline
post #2 of 3 (permalink) Old Oct 10th, 03, 05:50 AM
robert
rolling-robert's Avatar
welcome to team camaro.
btw: WE ARE NOT DEAF, YOU KNOW!!!
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #3 of 3 (permalink) Old Oct 10th, 03, 06:04 AM
if you got codes your ecm is alright ...start the car if it will, and tap on the maf(lightly not with a hammer)or flick it ....if a change in the engine is noted then its the maf wire is broken and laying intacked..if it starts and dies the little wire is broken and open not entacked ..as far as the maf relay you will find it is the same as the fuel pump relay on the 89's...hope this helps.. [img]graemlins/thumbsup.gif[/img]
gunny is offline
