Re: Engine starts ok, but immediately stops:
Another symptom, Puff, could be the ignition switch is faulty internally as in the the IGN position contacts have a high resistance between them.
How many times in the ign switch life has it been turned?
Every time a set of contacts get close enough, an arc will happen and over time a burn spot appears.
Ign switch can be taken apart - be sure to disassemble on a towel as it will catch the springs and other items falling out.
I did a cleaning job to one, un-swagged it, pulled apart, emery papered the contacts as they were black, and reassembled.
