Wrong engine/frame mounts? - Team Camaro Tech
post #1 of 32 (permalink) Old Jul 25th, 15, 11:14 AM Thread Starter
Chris
jumpstart's Avatar
Have always had an issue with the engine sitting too far rearward. HE I distributor was too close to the firewall and the transmission was very tight to get in the crossmember. I've attached a picture showing the passenger side frame mount. Both mounts seem to hang off the rear of the crossmember about 3/4". Are these the wrong mounts? 1969 small block car.
1969 X44, 355 SBC, BDS 6-71 blower, dual Eddy carbs, TCI Streetfighter TH350, 4000 stall, Denny's driveshaft, 10-bolt 8.5 rear w/4.56 gears, Caltracs, M&H drag radials, 10 point cage
jumpstart is offline
post #2 of 32 (permalink) Old Jul 25th, 15, 02:07 PM
Anne
Re: Wrong engine/frame mounts?
The 67-69 Camaros came with small body distributors.
To use a HEI distributor requires denting the firewall. You may not have any incorrect parts.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #3 of 32 (permalink) Old Jul 25th, 15, 02:27 PM
Smile Re: Wrong engine/frame mounts?
Yes, the frame mounts hang over the crossmember as shown. You may be able to gain some firewall clearance by shimming up your transmission mount. This could change your header to steering box clearance in a good way or a bad way. Also, check for fan clearance if you shim the mount.
TJS69 is offline
post #4 of 32 (permalink) Old Jul 25th, 15, 02:42 PM Thread Starter
Chris
jumpstart's Avatar
Thanks for the replys. Doing some more digging, I now believe I have 307/327 frame mounts, instead of the correct 302/350/396 mounts. Possibly the wrong motor mounts as well. Getting the #s together to source all the right parts.
post #5 of 32 (permalink) Old Jul 25th, 15, 03:55 PM
Steps
Also keep an eye on how the fan centres in the shroud.. espec at the bottom...
There are several different engine mounts and stands for different engines and yrs...
I still have the original stands.. in the car... and original trans and engine mounts from factory stored away with lot of other stuff... worn out.. but good reference.
My original trans mount is a good 10/ 12 mmm higher than the only 'off the shelf' mount available here....so the off the shelf mount has a spacer made of drilled steel bar and longer bolts.
Yes I have over the yrs got the wrong mounts and engine / HEI didnt sit right....
And also have put the wrong mounts on the wrong sides.. same result.
With corect mounts, and correct height trans mount... the fan sits slightly low in the shroud rather than dead center.. but think this is because of the after market replacement is slightly diff shape to the original
The HEI drops in, but the orginal HEI, cap thing that the HT lead boots clip in needs a few mm shaved off the back.
The HEI needs to be dropped in in factory position... #1 to the front , VA pointing to just behind the passengers head light....a tooth out either way once u have established your initial timing will put the HEI hard up against the firewall....
Once u have the HEI adjusted to your initial timing, with the rear 2 HT lead boots parallel to to the fire wall u will still have a light rub.
The only effect this has is around every 7 to 10 yrs u need to replace the slightly closest rear HT boot as it will wear and have HT spark leak... and the 7 to 10yr is on a daily driver around 50 to 70K miles
Steptoe is offline
post #6 of 32 (permalink) Old Jul 25th, 15, 09:02 PM
Don't bother changing your framestands and engine mounts. The 302/350 mounts aren't going to give you more room, they will give you less ! There isn't more than an 1/8" difference, and the 307/327 mounts will give you the most clearance at the firewall.
If it helps, I have the 302/350 mounts, an HEI AND a dented firewall.
I have researched the frame mounts and the engine mounts extensively... any questions... fire away.
TJS69 is offline
post #7 of 32 (permalink) Old Jul 25th, 15, 11:53 PM
Doug
Chris, Measure your frame bracket from the frame to the center of the bolt hole. The height measurement for a 69 302 frame bracket is left-1 7/16 & R-1 9/16. It uses mount part number 3990918. The low performance 67,68,69 frame bracket height is from frame to center of bolt hole L-2" and R-2 3/16. It uses mount part number 3990914.
Cdminter55 is offline
post #8 of 32 (permalink) Old Jul 26th, 15, 08:41 AM
George
I wish there were a cut and dry answer as to why some firstgens have no problem with a large hei and others require major surgery. Unfortunately, mine will not fit one. It would have made my life so much easier.
carbuff67rs is offline
post #9 of 32 (permalink) Old Jul 26th, 15, 09:22 AM
Banned
Chet
That's what hammers, small body HEIs, and Petronix conversion kits are for. That firewall is just a piece of sheetmetal that can be modified or restored how ever you see fit.
onefiness is offline
post #10 of 32 (permalink) Old Jul 26th, 15, 04:25 PM
Steps
Dunno about that...havnt had to hammer the firewall there, but having seen it from the inside and engine bay.. its close to a seam ....and looking at it, its going to take more than just abash with a hammer to make any significant dent.....and how the distortion may effect the seam... sealing in the future etc
Its not something I would be doing without a lot of forethought...
So if your combo.. using the higher factory trans mount or adaptation to it... or mounts/ stands dont work... or cant be bothered to mess around.... dont bash the firewall,
As suggested above, go to a small body alternative.
I only messed around because when I did.. it was before internet, before small body hei s etc
Steptoe is offline
post #11 of 32 (permalink) Old Jul 26th, 15, 05:30 PM
Ashlee and Andy
I have to second the small body HEI, i had a normal sized hei and had my cap get knocked loose by the firewall many times and decided to gut a distributor and do an HEI conversion.
But, there are commercial units out there, perfronix, mallory and msd come to mind
ap68 is offline
post #12 of 32 (permalink) Old Jul 26th, 15, 06:08 PM
George
I use a pertronix unit right now but I like the idea of the whole system, coil and all, in the large body hei. I dont want to have to mount an external box or coil. I like the idea of one wire and youre good to go.
post #13 of 32 (permalink) Old Jul 26th, 15, 07:49 PM
Anne
An external coil behind the air cleaner on the intake bothers you ? That's how they came from the factory.
Big HEI's bother me just like seeing the alternator on the wrong side of the engine.
Like seeing a "caution" sticker on a radiator shroud.
Like seeing an "air-gap" intake.
Like seeing an edelbrock carburetor.
Like seeing a serpentine belt drive.
I guess I'm just getting more cranky the older I get.
Ronald Reagan
post #14 of 32 (permalink) Old Jul 26th, 15, 10:01 PM
George
I dont have any of those things on my car. In fact, the reason why I have any problem with the external coil is because I have a 65 corvette intake on my car and it doesnt have the bolt holes for the coil mount. On the vette the coil bracket was bolted to the ignition shielding bracket so I had to rig my coil mount. It works fine but has always bothered me. And the hei has always been a very reliable setup for me on other vehicles.
post #15 of 32 (permalink) Old Jul 27th, 15, 06:09 AM
Anne
Well I learn something every day on here. I owned a 62 Vette and never knew of an intake that didn't have a coil bracket mount.
I was teasing anyway; hope you knew that.
Why not sell that Vette intake ? It's probably worth a lot more than a performer rpm.
Ronald Reagan
