What is this cylinder shaped thing? - Team Camaro Tech
post #1 of 31 (permalink) Old Jul 29th, 15, 07:25 AM Thread Starter
Almos
almano's Avatar
Hello,
Can You guys help me what the hell is this cylinder shaped thing at the left there? Do I need it?? Or just some environmental crap?
My restoration project:
1967 Camaro Convertible 327/210HP
almano is offline
post #2 of 31 (permalink) Old Jul 29th, 15, 07:46 AM
jerry
JERRYS 69 Z's Avatar
Re: What is this cylinder shaped thing?
Almos, that's the crankcase breather for the Early Chevy v8. You should have
A round draft tube that bolts onto the rear of engine and ends by the pan
Bottom. The early v8's did not have a PVC valve setup like now. Hope that
Helps.
JERRYS 69 Z is offline
post #3 of 31 (permalink) Old Jul 29th, 15, 07:57 AM Thread Starter
Almos
almano's Avatar
There was like a 90 degree elbow cap looking thing at the end of the engine what was connected to the carburetor bottom plate through a PCV.
Helps.
almano is offline
post #4 of 31 (permalink) Old Jul 29th, 15, 08:02 AM
That oil separator was used after the introduction of the PCV in 1963. The presence of that separator tells me that you have a small journal crank 283 or a 327. With the introduction of the large journal crankshaft in 1968 (1967 if you had a Camaro SS with a 350 engine) that piece was dropped from the block machining process and the PCV was moved to the valve covers.
Instead of a road draft tube, after 1962 there was a conical cap that had a hose barb that fed a hose up to the intake manifold were the PCV was screwed into the back of the carb, or the PCV was placed in the oil fill tube.
Big Dave
Larger Dave is offline
post #5 of 31 (permalink) Old Jul 29th, 15, 08:24 AM Thread Starter
Almos
almano's Avatar
This is what I have.
And I have a 327/210 1967
Big Dave
almano is offline
post #6 of 31 (permalink) Old Jul 29th, 15, 09:24 AM
George
Yes, I have the same engine and pcv setup. That baffle keeps the pcv system from sucking up oil during normal operation. Leave it on there.
carbuff67rs is offline
post #7 of 31 (permalink) Old Jul 29th, 15, 10:16 AM
Smile Re: What is this cylinder shaped thing?
Put a frost plug in the hole of the block after you throw the "can" and everything attached to it away.
TJS69 is offline
post #8 of 31 (permalink) Old Jul 29th, 15, 10:37 AM
Or after you sell the can to somebody who is looking for one. They are getting hard to come by.
Melrose RS is offline
post #9 of 31 (permalink) Old Jul 29th, 15, 11:13 PM
George
The only problem is then he has to change the pcv system to a valve cover setup. Which is fine but I think hes trying to keep the engine looking stock, and those script valve covers are a big part of that. I went through a similar dilemma at one point.
post #10 of 31 (permalink) Old Jul 30th, 15, 12:05 AM
The '67 and '68's have the PCV valve in the oil fill tubes, don't they ?
TJS69 is offline
post #11 of 31 (permalink) Old Jul 30th, 15, 08:05 AM
Gary
69Z28-RS's Avatar
Carbuff posted...
"Yes, I have the same engine and pcv setup. That baffle keeps the pcv system from sucking up oil during normal operation. Leave it on there. "
I'd suggest modifying this statement slightly.. you should first CLEAN that baffle can by soaking in a solvent. it's filled with a wire mesh filter (like a metal brillo pad) which prevents oil from getting out the draft tube, but after many years they become clogged and also can prevent the pressurized oil vapors from escaping . So clean thoroughly and then replace if you are rebuilding that engine.
PS. If anyone has an unused 'adaptor for the rear of the engine' (which replaced the draft tube in '63 or so?).. and which provided vent connection to carb or intake, I'm interested in purchase of one to eliminate the draft tube for a 1960 engine.I'm rebuilding.
Gary
Gary
69Z28-RS
Corvettes (5), Nomads (2), El Camino, etc
69Z28-RS is offline
post #12 of 31 (permalink) Old Jul 30th, 15, 09:39 PM
George
The 67 210 hp 327 uses either an open system (48 state) or a closed system (cali smog setup). The open system has the pcv valve at the back of the carb connected to that hole in the back by the distributor. Intake breather is a breather cap on the oil fill tube. In the closed system the pcv valve is in the oil fill tube with a closed cap and the air intake breather is through the hole in the back to the air cleaner. Either way, the valve covers are solid closed. Im not sure about the 68 systems.
post #13 of 31 (permalink) Old Jul 31st, 15, 12:17 AM
I was just thinking that you could put a pcv valve in the fill tube instead of putting one in a valve cover.
TJS69 is offline
post #14 of 31 (permalink) Old Jul 31st, 15, 01:40 AM Thread Starter
Almos
almano's Avatar
Yeapp this is my system the 48 state. I think I leave like that. But I don't like the fact that the dirty gases full with CO goes back to the fresh air destroying the ideal AFR. Not best for getting the maximum performance out of an engine.
almano is offline
post #15 of 31 (permalink) Old Jul 31st, 15, 09:45 AM
George
Sure, you could do that. But there has to be a breather to let fresh air in the engine to take the place of the air youre sucking out. Preferably on the opposite side of the engine like the factory does. If
you relied on the vented oil fill cap then the pcv valve would just suck fresh air from the vent being so close and not suck out any blowby gasses. You need that front to back air flow to clear out the gasses. Or side to side as the factory eventually went to with the valve cover setup.
