2-Bolt vs 4-Bolt - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 10th, 03, 10:45 PM Thread Starter
Out of sheer curiosity, how many people here own 2-bolt 350cid engines? For those that do, How pleased are you with it and why did you choose it over a 4-bolt? Please tell us.
garfield is offline
post #2 of 9 (permalink) Old Sep 11th, 03, 03:11 AM
Chris
I have used 2-bolt blocks mainly due to their increased availability. I like them and have had no failures either in racing or towing conditions. Having said that, most of my race engines are 450hp or less, and my towing conditions are not extreme.
Chris
68 Camaro, 555 big block, Doug Nash 5-speed, 3.54 gear.
smits67 is offline
post #3 of 9 (permalink) Old Sep 11th, 03, 03:42 AM
Rick
Mine came with a 2 bolt and it's held up well.
On a rebuild I would go with ARP studs for extra insurance.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #4 of 9 (permalink) Old Sep 11th, 03, 04:21 AM
Codi's Avatar
Angry
In the old days when I was racing and building engines, I used only a few 4 bots, mostly 2 bolts. With ARP studs and proper machine work and balancing, I never had a failure. Other things may have broken, but never had a problem with 2 bolts. Keep in mind, these were'nt 800 hp motors, mostly around 500 to 650 hp. A 4 bolt is nice, a 2 bolt is very OK.
Daddy's Hot Rod.
Codi is offline
post #5 of 9 (permalink) Old Sep 11th, 03, 06:47 AM
I would worry more about using a late 70s block than whether it was 2 or 4 bolt. The earlier the block the better. Most of the light blocks (ones with only about half as much vin. pad)that I have come across are cracked in the lifter area. If you lift an early block then do the same to a later one you can't believe how much heavier the early is.
oger is offline
post #6 of 9 (permalink) Old Sep 11th, 03, 07:01 AM
Royce
My 385 (stroked 350) is a 2 bolt, it has been together a long time and has seen some abuse. I did use ARP studs. My 383 is also a two bolt but, I had it splayed. Two bolts are fine and I actually prefer them, if you are going to go extreme then just have it splayed. I have also read that 2 bolts are actually stronger that 4 botls.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #7 of 9 (permalink) Old Sep 11th, 03, 08:40 AM
Have had both, neither ever failed. The 2 bolt engine has ARP studs while the 4 bolt engine has factory windage tray studs on it.
I like 2 bolts better because they are cheaper and easier to find. [img]smile.gif[/img]
-Mark.
stingr69 is offline
post #8 of 9 (permalink) Old Sep 11th, 03, 09:07 AM
Matt Jones
Ditto.
Use the extra money you would have used to buy the 4-bolt to get yourself some ARP rod bolts, main studs, etc.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #9 of 9 (permalink) Old Sep 11th, 03, 11:58 AM Thread Starter
Originally posted by Silver69Camaro:
Ditto.
The way things are looking right now, I think this idea would be best...Thanks!!
When you buy an American car, you provide work for a man and his family for three months. -Jay Leno
garfield is offline
