engine mockup ? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 15th, 04, 11:06 PM Thread Starter
Big daddy
Would it be wise to have 2 sets of bearing when mocking up 383 for clearance.one for mockup and one for finale ***.?Also,do I mockup with rings installed on pistons.This is my first build. thanks.
[ 04-19-2004, 10:34 AM: Message edited by: carhodge ]
67ssclone 383 4spd 3.73 vintageair
carhodge is offline
post #2 of 5 (permalink) Old Apr 16th, 04, 01:57 AM
Wouldn't hurt to have two sets of bearings. Otherwise, use plenty of assembly lube when turning. No, rings are not a requirement.
Everett#2390 is online now
post #3 of 5 (permalink) Old Apr 16th, 04, 05:27 PM
Bill
Hodge,
Its hard to keep every bit of dirt from getting in the bearings. Run down to your machine shop and see if they have an old set they can give you for mock up. You really only need a front and a rear. We have found that grease works better at keeping the grit out from grinding as compared to oil.
Hope this helps,
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #4 of 5 (permalink) Old Apr 18th, 04, 04:16 AM Thread Starter
Big daddy
Bill,what do you mean by front and rear?
carhodge is offline
post #5 of 5 (permalink) Old Apr 19th, 04, 08:32 PM Thread Starter
Big daddy
thanks all...
carhodge is offline
