Floating pin lube - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 10th, 03, 05:29 AM Thread Starter
What would you folks recommend to lube up a set of floating pins? The last set I did (KB's) came with Torco lube, but these wiseco's didn't come with anything. Nobody carries Torco around here.
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #2 of 3 (permalink) Old Aug 10th, 03, 01:34 PM
Motor oil is all I use. The clearances are very close so it can't just run out. If you are realy worried about it, you might try that clear red sticky cam break-in stuff.
-Mark.
stingr69 is offline
post #3 of 3 (permalink) Old Aug 10th, 03, 04:28 PM
Bill
Travis,
I use the GM EOS lube. It tends to stay there if the engine is not started for a while.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
