Does this compression look OK? - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 23rd, 03, 10:27 AM Thread Starter
I recently had larger valves put into the heads on my 396 (2.19 In. 1.88 Ex.). I have been driving it for a couple weeks and decided to do a compression test.
Here are the results,
1)212 2)223
3)210 4)210
5)200 6)215
7)205 8)217
Several months ago I did a compression test and the numbers were in the 160/170 range. This was before the new valves.
I am concerned about the compression being too high. I am getting a bit of (spark knock) when I accelerate. I assume this is detonation. I am running 92 Octane Super but this does not seem to help.
How does #5 look compaired to the others? Is this something to worry about?
Thanks,
Team Camaro Gold #137
Team Chevelle 1856
ACES #6768
69 Camaro SS396. Hugger Orange, Holley MPFI, TKO600 5spd, 12 Bolt 3.55.
sgaylord is offline
post #2 of 3 (permalink) Old Jul 23rd, 03, 12:33 PM
Those are some pretty serious compression readings. Did they shave the heads any when they did the valves. Did they CC the chambers after the valves. The new larger valves could be sitting farther into the combustion chamber making the volume smaller and raising the compression. Depending on the cam, you might have too much compression.
kwissman is offline
post #3 of 3 (permalink) Old Jul 23rd, 03, 01:00 PM Thread Starter
They did shave the heads. I did not have them cc'd. Is there anything I can do the help this? Bigger head gasket?
Team Chevelle 1856
ACES #6768
sgaylord is offline
