Stripped holes in damper (454) - Team Camaro Tech
post #1 of 13 (permalink) Old Apr 21st, 04, 08:37 AM Thread Starter
Can you heli-coil the three pulley mounting holes in the harmonic balancer
Without messing up the balancing of the engine (454)
[ 04-21-2004, 02:34 PM: Message edited by: 69' 468-5spd ]
69' 468,510hp dyno'd roller,Doug Nash 5spd,9" ferd 4.11,Posi<br />Hope for mid 11's
69' 468-5spd is offline
post #2 of 13 (permalink) Old Apr 21st, 04, 08:57 AM
Vintage 68's Avatar
Angry
I have fixed one or two if necessary - never ran into all of them being stripped.
The answer is yes - if you install the correct length Heli-coil and use loctite Red to install the insert.
I have saved several this way and never had a failure.
Do not try to increase the bolt size.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 13 (permalink) Old Apr 21st, 04, 10:05 AM Thread Starter
Thanks, I am a little weary of drilling holes in a already balanced damper.
I bought this damper new in a box at a swap meet. I never checked the holes before I sent it down with the engine to be balanced. When I got it back I installed the pulley's (already in the car) and found all three holes to be stripped out. I was using 3/8-16 X 1Ē bolts, are (where) they UNF or UNC threads?
Also I noticed I have a clearance problem with the
pulley's and the front crossmember ('69). I can't
get a belt on it. Is this comon with aftermarket
pulley's?
post #4 of 13 (permalink) Old Apr 21st, 04, 10:10 AM
Bill
My old 355 had heli coils in the damper and it worked fine.
WildBillyT is offline
post #5 of 13 (permalink) Old Apr 21st, 04, 11:27 AM
Gary
I have stock pulleys on my 69 427, and there's barely enough clearance to slide a belt in the largest one. You have to work the belt back and forth to get the belts on. I am using the original stock (non-interlocking) motor mounts on the correct b/b towers. I looked at later interlocking motor mounts, and they would drop the motor about 1/2". Therefore, they were not an option.
Unreal is offline
post #6 of 13 (permalink) Old Apr 21st, 04, 11:34 AM Thread Starter
I have the BB posts and Moroso solid mounts
with a TH400 rear mount holding a Doug Nash
5speed. With this combo, I have about 1/4"
under there...the belt won't go on without
force.
I'm not worried about the heli-coils, it's the
balancing I'm concerned with.
post #7 of 13 (permalink) Old Apr 21st, 04, 12:02 PM
Vintage 68's Avatar
I was using 3/8-16 X 1” bolts, are (where) they UNF or UNC threads?
Drilling the holes with the size for the Heli-Coils will not effect the balance.
The bolts are Fine thread. You will of course need a 3/8" X 24 Heli-Coil set.
1968 Convertible
Some trucks
post #8 of 13 (permalink) Old Apr 21st, 04, 12:10 PM Thread Starter
Thanks V-68,
post #9 of 13 (permalink) Old Apr 21st, 04, 01:21 PM
Just curious - why not? If you did all 3....
BPOS is offline
post #10 of 13 (permalink) Old Apr 21st, 04, 01:39 PM
Vintage 68's Avatar
Talking
Originally posted by BPOS:
</font><blockquote>quote:</font><hr />Originally posted by Vintage 68:
Just curious - why not? If you did all 3.... </font>[/QUOTE]Well... Because I've had to fix someones attempt to do this. [img]graemlins/clonk.gif[/img]
It's not Balance or that increasing the hole size in the Damper-web reduces it's strength, as much as the Pulley holes also need to be increased for larger bolts.
Getting all these holes properly centered is difficult, at best, with hand tools.
I would recommend the Heli-Coil route. [img]graemlins/thumbsup.gif[/img]
1968 Convertible
Some trucks
post #11 of 13 (permalink) Old Apr 21st, 04, 02:00 PM
ZZ_430's Avatar
Helicoils will be fine.
I thought BB used 3/8 X 16 UNC threads.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #12 of 13 (permalink) Old Apr 21st, 04, 04:01 PM
Bill
69,
Just curious ... have you driven that thing yet with the Nash 5 spd and the 4.11 gear ?? I have the same trans for my 71 and I figure even a 3.31 gear might be too much with the low first gear of the DN.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #13 of 13 (permalink) Old Apr 22nd, 04, 04:30 AM Thread Starter
No not yet but I figure with a 2.02 second
gear that with the 4.11's I would be somewhat close the 2.20/2.54 M-20's and M-21's I ran. On the street I can just start with 2nd gear.
I hope to try it soon, I'm getting anxious to say the least.
