engine cranks to long - Team Camaro Tech
post #1 of 11 (permalink) Old Dec 31st, 04, 09:29 AM Thread Starter
hey guys i have a ? about my engine. for some reason it tends to crank for a bit before it fires up, even after the engine is warm. it will crank for a good 5 seconds before it will turn on. what causes this. its not fuel injected but i figured it should fire up pretty easily once the car has warmed up.
thanks,
zack
zack 68 is offline
post #2 of 11 (permalink) Old Dec 31st, 04, 09:52 AM
some engines are just like that- what kind of carb are you using? what's your starting procedure? where's your initital timing set at? how fresh is the engine? what kind of compression are you running? choke or not? points or HEI?
there are a lot of variables- but if you have a fresh 10:1 engine with 15 degrees of inittial timing cranked into your HEI distributor and a fresh q-jet on top of it- it should almost fire right off.
but if you have a 100,000 mile engine with a dying Holley carb on it with 5 degrees of initial timing in your old points distributor with worn out points, then you might have a little bit of cranking time before things light off.
i know i probably didn't help much, but i kind of felt like typing..
you don't plan sincerity.
novaderrik is offline
post #3 of 11 (permalink) Old Dec 31st, 04, 10:08 AM Thread Starter
hey derek,
its a newly rebuilt engine. 9.5 to one compression, mallory unilite dis. carter competition 4bbl carb, 280/280 adv duration cam with .450 lift,edelbrock performer intake,hooker supercomp headers. any ideas? the timing was set with the #1 piston at tdc but i don't know if the timing is advanced or retarded?
zack 68
zack 68 is offline
post #4 of 11 (permalink) Old Dec 31st, 04, 10:34 AM
Kevin
KevinW's Avatar
Mine has always taken long to fire, original 327 engine and new 350/300 engine. They both did the same thing. The only thing that is common to both engines is the electrical. I have not figured it out yet.
Kevin
KevinW is offline
post #5 of 11 (permalink) Old Dec 31st, 04, 11:35 AM
Bob
It soumds to me like you are losing your fuel prime to the carb. You also don't want your timing at TDC. Usually you want between 8 and 15* of advance. If you pour a little gas in the carb will it fire right off? If you pump the throttle rod do you see fuel squirt into the carb? Is it vapor locking?
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
phel69 is offline
post #6 of 11 (permalink) Old Dec 31st, 04, 01:39 PM
Thomas
I would start with the timing. Once you eliminate that problem if it still won't fire right up move to the fuel delivery system. Good luck...
70rs
Slomaro is offline
post #7 of 11 (permalink) Old Dec 31st, 04, 03:01 PM
Chad
67 Plum's Avatar
Make sure you are getting 12 volts to the ignition when cranking.Low voltage will make one slow to start.
67 Plum is offline
post #8 of 11 (permalink) Old Dec 31st, 04, 03:20 PM
JohnZ's Avatar
Originally posted by zack 68:
hey derek,
zack 68
Put a timing light on it and set it correctly (with the vacuum advance disconnected and plugged); if you don't know what the timing is, you don't have any baseline to work from. [img]graemlins/thumbsup.gif[/img]
JohnZ
CRG
JohnZ is offline
post #9 of 11 (permalink) Old Dec 31st, 04, 03:32 PM
You should be able to tap the accellerator pedal to set the choke and give it a shot of fuel. It should fire within the first few revolutions. Do you have a choke? Do you tap the accellerator pedal once to trip the choke mechanism before starting?
dnult is offline
post #10 of 11 (permalink) Old Dec 31st, 04, 03:34 PM Thread Starter
yes i do hit the pedal a couple of times before a cold start, and it does start up quickly, but after its warm should i still have to give it gas to get it to start? also my balancer doesn't have a timing strip on it. [img]graemlins/sad.gif[/img] can i buy one to stick on it or do i have to get a balancer with it allready? thats the reason i set it with the #1 piston on top and not a timing light. could this also be robbing my HP. i feel the car should accelarate better than it does.
zack 68
zack 68 is offline
post #11 of 11 (permalink) Old Dec 31st, 04, 03:52 PM
Timing off can for sure rob power.
There's about azillion different combinations of balancers and timing tabs, some tabs are built into the cover, some use 2 of the cover bolts.
The balancer should just have a single groove in it.
If you know the part # of the balancer, or the car/engine it came from, dealer can probably look up the right tab.
Or you could just do the "set it by ear method".
