timing mixup - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 25th, 03, 09:18 PM Thread Starter
toy
i have a 68 327 210hp with a after market timing chain cover are the timing marks supposed to be directly above the balencer or off to the right like all the chevy motors i've delt with timng wont read but motor runs great by ear i just cant really degree the cam very well with no measurements
toy is offline
post #2 of 2 (permalink) Old Sep 26th, 03, 04:27 AM
a67
A '68 with the short water pump the timing tab would have to be off to the drivers side (left). Also need to check the damper. There are two damper timing mark locations. One nearly in line with the keyway and one with the mark about 12 degrees from the keyway.
The damper with the TDC mark inline with the keyway takes the timing cover with the tab to the left (drivers side).
The damper with the TDC mark offset (noticeably) takes the timing cover with the tab directly above the damper.
Bob.
a67 is offline
