Engine ID - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 1st, 01, 05:00 PM Thread Starter
Can anyone tell me anything about an engine based upon the following:
V0519DJS
I have been told that the 05-19 indicates May 19th, however, I've been unable to decipher the remaining characters.
tango1112 is offline
post #2 of 8 (permalink) Old Jan 2nd, 01, 11:25 AM
The best I can do is give you the information that I have The V says the motor was installed in Van Nuys CAThe 0519 you are corrrect but the remaining charicters I cannot figure I looked through out my camaro data book but could not get you that number. Sorry <BLOCKQUOTE>quote:</font><HR>Originally posted by tango1112:
V0519DJS
<HR></BLOCKQUOTE>
ltlrufo is offline
post #3 of 8 (permalink) Old Jan 2nd, 01, 05:29 PM
Jonesy's Avatar
V = Flint, MI engine plant
0519 = May 19th
DJS = ?? look at this again. Maybe wire brush it.
Also find the casting number on the back of the block, on the bellhousing flange, drivers side.(something like 3970010)
Casting date will be on the same flange directly behind the distributor. (something like E 11 2)
Jonesy is offline
post #4 of 8 (permalink) Old Jan 5th, 01, 06:23 PM Thread Starter
I looked to see if the ID was correct and it is V0519DJS. The only other number I can find is on the rear. 14093638 Any Ideas?
post #5 of 8 (permalink) Old Jan 7th, 01, 03:17 PM
tango1112,
The only thing I can find with that number is '86 to '94 350. Jonesy is correct, DJS is not correct. If you can find the correct suffix, it will tell us more.
Rick
ryork is offline
post #6 of 8 (permalink) Old Jan 7th, 01, 05:19 PM
Chevy three digit codes start with C for cars and T for trucks. I suspect you have a small block that was in an Olds or Pontiac. That would make it a 305 more than likely if so.
tom3 is offline
post #7 of 8 (permalink) Old Sep 4th, 01, 11:04 AM Thread Starter
V0519DJS
<HR></BLOCKQUOTE>
post #8 of 8 (permalink) Old Sep 5th, 01, 01:10 PM Thread Starter
Cool
I still have the same problem. Are there any resources on the internet to help with decoding engines. I have spent hours searching the net for more info. all to no avail.
