700r4 question - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 6th, 01, 12:24 AM Thread Starter
I am building up my vette so I am using many of the parts in my daily driver. It is a 78 GMC 4x4. New 355 SB Mild Cam (bullet 280) L88 heads 750 holley headers 9.5:1 cr. My question is what will have to be changed/ modified, if anything, to put the old 86 700r from my vette (just brought the thing couple years ago)in my 4x4. Can I do it, should I do it? I really like the OD. Suggest t-converter etc.
tonysparks is offline
post #2 of 6 (permalink) Old Jan 6th, 01, 05:29 AM
I would suggest a good rebuild. I've had really good luck putting a heavy duty clutch pack between 3-4 gears, putting a high rev spring kit in, a good shift kit will help, and you'll need a lockup kit to make the lock up converter work right. The last time I had all this done it ran me $800 and I havn't had any problems. The 700-R4 is more than enough tranny to hold a wild small block if they are modified correctly.
Matthew Baker is offline
post #3 of 6 (permalink) Old Jan 6th, 01, 05:31 AM
Sorry, I don't know how it will hook up with your transfer case or if it even will.
post #4 of 6 (permalink) Old Jan 6th, 01, 09:21 AM
to put it on your 4wheeler you need to have the right tail shaft put in it..a very short one iff you tak the one out of your rig now i belive it is a THM350 the 700R4 should just bot up to teh tranfercase adaptor, you might have to moove it back a few inches. other than that you will need a T.V cable and 700R4 wire kit from some one..they run around 100 buck's, oh and a bvraket for the T.V. cable...hope this help's.
ilbl8 is offline
post #5 of 6 (permalink) Old Jan 6th, 01, 04:00 PM
The Corvette transmission case does not have a pad for a rear trans mount. I'm not sure but if the 4x4 mount is on the transmission, or transfer case. If it is on the trans, the the Vette trans won't work.
TTFN
Mat
Mat Klemp is offline
post #6 of 6 (permalink) Old Jan 6th, 01, 07:47 PM
Tony,
The 700 will fit, and has already been said the 4x4 takes a shorter output shaft. The case of the 700 is longer than the 350 so it takes a different adapter for the transfer. the one from the 350 will bolt on but the drive shafts won't fit and the output shaft will be to short to spline into the transfer. Call the local dealer and get the adapter from them. Ask for 1982 up 4x4 700R4 transfer adapter.
Also 86 is the last year that you can lock it up w/out electrical. This tranny can be locked up hydraulic.
Get the vette converter rebuilt, or one like it, they are around 2200/2400 as are. I use these, and my converter man furnace brazes them, and adds the late converter clutch.
Larry
lnjstreetrods is offline
