Help - 69 Z/28 Harmonic Balancer?? - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 13th, 05, 06:59 PM Thread Starter
Jeff
What is the difference in the 69 Z/28 Harmonic balancer #3947708, from the other 8" balancers?
I am having a lot of trouble finding an original balancer - Can I use something else that looks the same?
Which should I choose?
Thanks,
Jeff
Pacecarjeff is offline
post #2 of 8 (permalink) Old Jan 14th, 05, 05:47 AM
"Tri-Tip"
Gary L's Avatar
The original balancer has 3 large spokes on the front going almost to the very edge. The replacement balancer will work just fine. If you find an original send it to The Damper Dudes to get rebuilt. I can email a picture if you like, or look in Jerry MacNeish's book.
Gary L is offline
post #3 of 8 (permalink) Old Jan 14th, 05, 03:37 PM Thread Starter
Jeff
Angry
Thanks for the info.
Saw the picture on page 46.
JM says the early balancer will fit, just the timing mark is different.
Might try the earlier one if I find one.
The replacement balancer I got from Chevrolet this week is not even close.
It has a big section cut out on the side.
The front is 8" while the back is 6".
The part number has been replaced again.
I am going to hit the junk yards this week-end and see what I can find.
Where can I find the Damper dudes, and how much do they charge?
post #4 of 8 (permalink) Old Jan 15th, 05, 03:40 AM
"Tri-Tip"
Gary L's Avatar
Damper Dudes
6180 Parallel Dr.
Anderson, CA 96007
1-800-413-2673
It cost about $100.
Gary L is offline
post #5 of 8 (permalink) Old Jan 15th, 05, 10:22 AM Thread Starter
Jeff
Thanks!!
post #6 of 8 (permalink) Old Jan 17th, 05, 11:36 AM Thread Starter
Jeff
Now I have to find a Core... any clues?
post #7 of 8 (permalink) Old Jan 17th, 05, 05:23 PM
"Tri-Tip"
Gary L's Avatar
Watch the Classified section on this site evry day. Also put a wanted ad here. [img]graemlins/thumbsup.gif[/img]
Gary L is offline
post #8 of 8 (permalink) Old Jan 18th, 05, 10:33 AM Thread Starter
Jeff
I did that first. No luck for the last 2 weeks.
