Alternator mount that doesn't bolt to the intake - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 8th, 03, 08:44 PM Thread Starter
Just curious what you guys are running. There is no alternator mount provisions on the weiand 7530 I am using. My old alternator mount bolted to one of the thermostat housing studs, but this new intake has the thermostat sitting a lot higher than before, so it won't work. Thanks!
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #2 of 7 (permalink) Old Sep 8th, 03, 09:06 PM
Lonnie
Summit has an inexpensive copy of the March brackets. Don't know about quality of the Summit stuff. Or try here http://www.alangrovecomponents.com/Catalog.htm
Lonnie
67 Camaro [email protected], [email protected], 1.455 60ft 421sbc
Lonnie67 is offline
post #3 of 7 (permalink) Old Sep 8th, 03, 09:28 PM
just take the factory bracket and cut the mounting ear off- seen that done dozens of times. what you then end up is just like the aftermarket setups, but cheaper. you could even weld up an end to mount it to the water outlet, if you feel like doing more work than necessary.
you don't plan sincerity.
novaderrik is offline
post #4 of 7 (permalink) Old Sep 9th, 03, 01:26 AM
Don't you need to add a stud-headed bolt at the top W/P drivers side location to do this right when you trim the bracket, too???
Or am I thinking of the pass. side bolt and the bat. cable???
pdq67
post #5 of 7 (permalink) Old Sep 9th, 03, 02:37 AM
Rick
I have the Alan Grove item. It nicely places the alternator tight to the water pump just below the pass head. Allows a short belt too.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #6 of 7 (permalink) Old Sep 9th, 03, 03:55 AM
Cool
The '88 Monte Carlo I have has an Edelbrock manifold on it. OEM was to the t/s housing, w/pump, and to the alt adjusting slot. I used the w/pump point and left the t/s stud out of the picture and have no problem with belt alignment or jumping.
post #7 of 7 (permalink) Old Sep 9th, 03, 04:02 AM
I just went through the same problem. My stock alternator location was using the water neck mount.
After alot of looking I found two good systems. One is the Alan Grove mount for $35. For $14 more you can get the entry level March Performance mount.
I went With the March Performance mount and like it alot. I paid $49 at Summit part number MCH-20123. For another $20 you can get it polished and clear coated. For a bit more they have one that has more of a cool design.
jrager is offline
