pushrod length? - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 16th, 03, 12:36 PM Thread Starter
I am having trouble picking the correct length pushrod to use with my engine. it is a 327 small journal, with trickflow 23 heads, 1.5 rockers, and hydro lifters. i can't find any info anywhere about how to correctly select length.
please help
thanks in advance
ben
a67camarolover is offline
post #2 of 3 (permalink) Old Sep 16th, 03, 02:39 PM
Cool
You probably need to pick up a Manley plastic P/R checker that is made for this..
Or, the shade-tree way by cutting an old P/R in two and adding a length of threaded bolt and a nut so that you can adjust it to fit your application. Then see if you need custom ones or what..
pdq67
post #3 of 3 (permalink) Old Sep 17th, 03, 08:35 PM
SY1
I made my own just like pdq did. I used the thicker 3/8" pushrods since they're not good for anything else, tapped them for fine thread after cutting one in half and ground a couple flats on each end near the cut so i could use a small wrench if I had to on them. Substituted a solid lifter while doing the measuring and it works great.
"..............what, and get out of aviation??"
SY1 is offline
