Fuel pump return line blocked - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 4th, 03, 09:19 AM Thread Starter
I noticed that my mechanical fuel pump has three lines coming out of it, one for fuel in from the tank, one going to the carb and the return. My return line has a bolt in it blocking it off, right out of the pump.
How bad is this and why would someone do this?
jrager is offline
post #2 of 3 (permalink) Old Sep 5th, 03, 09:22 AM
robert
rolling-robert's Avatar
to me, thats pretty dumb
if the carb has enough fuel, the pump wil still be pumping fuel, so there must be a bypass, or else it will force the fuel into the carb and it will flood.
thats what i think about it.
get rid of the bolt and make it as it should be.
sounds like the previous owner didnt know what to do with it.
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #3 of 3 (permalink) Old Sep 8th, 03, 09:11 PM
David Pozzi
davidpozzi's Avatar
Not many camaros came with the return line back to the tank. I think only some air conditioned cars. If your car has the line, hook it up. If not, the pump return line can be plugged.
Factory typ pumps with the return line on them are low perf pumps and not up to providing enough fuel volume for high performance.
davidpozzi is offline
