Transmission Oil Cooler - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 14th, 01, 04:20 AM Thread Starter
I want to know if adding a transmission cooler to my car will make a difference?
Alfonso Perez is offline
post #2 of 6 (permalink) Old Feb 14th, 01, 07:17 AM
Daniel
What car, transmission, engine? Usually it is good to add because it keeps the trans fluid cooler and in turn keeping the fluid from braking down.
67ss350camaro is offline
post #3 of 6 (permalink) Old Feb 14th, 01, 07:33 AM Thread Starter
Smile
1979 Chevy Camaro, 350 transmission, 305 engine? Usually it is good to add because it keeps the trans fluid cooler and in turn keeping the fluid from braking down.
post #4 of 6 (permalink) Old Feb 15th, 01, 09:00 AM
Running a seperate transmission cooler helps with two things. One, it helps with engine cooling, since the transmission is not putting extra heat into the radiator. The second point, is that the coolers due a better job than the radiator at cooling. If you tow, or have a high stall, a seperate cooler is the way to go. I run a 8" 4500 rpm stall on the street. I installed a cooler and added a 9" fan to it. The transmission runs just below 200 degrees on the street.
1992 Firebird 355/Six Speed (Soon to be LT1)
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
"Speed KILLS, so drive a FORD and live forever!"
http://personal.lig.bellsouth.net/~racer383/
Member of the "unwanted" 3rd Gen group.
Mark W. Winning is offline
post #5 of 6 (permalink) Old Feb 15th, 01, 09:23 AM
If the car has a stock converter in it and you don't tow anything I would leave it alone. A trans cooler will help the engine run a little cooler but not much. The biggest problem is that the transmission runs to cool if you don't leave the cooler in the radiator hooked up.
oger is offline
post #6 of 6 (permalink) Old Feb 16th, 01, 11:43 PM
Joe
How does running too cold hurt the tranny?
It should not get moisture like the engine does since it doesn't see combustion.?
Joe
69 SS396 Clone, B&M TH400, 3.55 12 Bolt Posi, Blue w/White Z28 Stripes, Chrome Rally Wheels
[email protected]
Joe G is offline
