big block head gasket - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 17th, 03, 10:57 AM Thread Starter
kip
is anyone running a gasket thinner than .039 on their big blocks, could you list the part number/manufacturer? not looking for custom copper either...
thanks for the help
kip is offline
post #2 of 8 (permalink) Old Sep 17th, 03, 05:38 PM
Vintage 68's Avatar
You didn't say what bore and block type but check with Chevy/GM as they make a Steel Shim that's @.022" for both the MarkIV and the GenV.
#14015351 = MkIV @ 4.250
#12555728 = GenV @ 4.250
All other s I know of are above .038"
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 8 (permalink) Old Sep 19th, 03, 01:57 AM Thread Starter
kip
great, thanks vintage68.
sorry for the lack of info, its an early 70's 30 over 454(4X4.28)goin in my friends 68 coupe.
0.022 would be great. i will check those out. i ran a 0.015 steel shim on a 327 and am looking for something similar to dial in the compression.
kip is offline
post #4 of 8 (permalink) Old Sep 19th, 03, 02:05 AM Thread Starter
kip
just realized mkIV/genV is '87-95. would these gaskets not work on a 70's block? bear with me, i'm new to big blocks...
thanks again.
kip is offline
post #5 of 8 (permalink) Old Sep 19th, 03, 05:52 AM
Vintage 68's Avatar
Angry
The "70's" block should be a Mark IV type.
They were producted from 1965 to 1990.
Gen V was producted from 1991 to 1995.
Gen VI's were started, along with the "Vortech" name, in 1996.
The gasket # for Mark IV will work fine. And if the block turns out to be a Gen V then there is a gasket for that too. I have heard of a Shim-type for Gen VI - but I've never seen or used one.
Be sure to lay-it-up on both the block and head to be sure it completely lines up, just good engine building practice.
Miss one hole and you are looking for overheating and other problems.
On a Gen V/VI be sure the front block casting hole is blocked off by the gasket and the coolant goes through the rear hole or the rear of the block will get 'Mega-Hot' and the gauge will read fine.
btw - I always use Chevy/GM Gaskets on these, but Mr.Gasket used to sell a Steel Shim type for the Mark IV as part #1131 - may still be available.
1968 Convertible
Some trucks
post #6 of 8 (permalink) Old Sep 19th, 03, 06:18 AM Thread Starter
kip
i found the first gasket you mentioned from GM, #14015351, 0.022 steel shim for '65-90 blocks. that'll get us in the compression window we're shootin for without shaving the heads,cheaper also. i'll check out the mr. gasket part you mentioned.
thanks for the help!
kip is offline
post #7 of 8 (permalink) Old Sep 19th, 03, 07:33 AM
Kip, Not sure if you are using iron or aluminum heads.Just throwing it out there so you are aware. If you are going to use aluminum heads, you shouldn't use steel shim head gaskets.
Dean
bilydean is offline
post #8 of 8 (permalink) Old Sep 19th, 03, 01:17 PM
Smile
I gave like $18 for my pair of aftermarket .022" steel shims a while ago before I put my Mark IV, 496 together so they are out there and not priced too bad, imho..
pdq67
