HElp Please - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 29th, 04, 04:48 AM Thread Starter
Hey guys Help me out Im just learning ok
I picked up a 350 the only # i found on it was on the block located right at the fuel pump the numers was kinda like this
21
137599
ok the casting (raised letters)GM 3970010
I got this out of a 69 camaro
found these numbers as well on the pad under the alt bracket 010 on both sides of block 010 on back around the bellhousing area across from the Raise Casting was more raised casting D237
heads 333882
so if you can tell me what year and all this is I would be so happy! thanks guys!
KCBlkPanther is offline
post #2 of 2 (permalink) Old Aug 29th, 04, 05:12 AM
There is a pad on the deck just above the pass. side top water pump bolt as well as maybe one right above the middle of the top of the water pump pulley..
On the pad(s), there should be a string of numbers and letters.
Post the letters b/c they decode the engine size to year and type of vehicle, (and possibly carb. and tranny type), the engine originally was in when it came out of the factory.
If the number/letter string isn't there, the block has been decked and you can't tell what it actually came out of.... (SOL!!!).....
I love it when I go to car shows and the Dude says all original, but the motor has been decked and has no ID code and then has the wrong valve covers and pcv on it thing!!!!
pdq67
