Fuel Line meets header - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 10th, 03, 07:17 PM Thread Starter
Arrow
I wasn't sure where to put this one, so I decided on Engine. I noticed tonight that my passenger-side header comes within 1/8" of my fuel line (I have two fuel lines...from what I read here one is incoming & one is return for my Q-Jet). I haven't started it yet...pretty dangerous, I thought.
If I cut the fuel line(s) before they get near the header (there is also a close encounter of 1.5" where the header will mate to the converter), and add a steel flexible hose routed to the fuel pump, is this safe? About 3' of flex hose if I did that. I could route it (in the engine bay) on top of the coil spring instead of upward toward the top of the strut. Does anybody have any suggestions?
1982 Camaro, 305, 4bbl Q-Jet
Scott Reeves HSV is offline
post #2 of 3 (permalink) Old Oct 11th, 03, 03:05 PM
Rick
I have used the thermo-tech insulating material with good results in tight places. I bought it from Summit. I too have a fuel line that is close to a header tube and my exhaust is very tight to the floor in some places. I used their line wrap for the fuel line and self adhesive sheeting for the floor areas. They claim to reflect a significant percentage of the heat.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #3 of 3 (permalink) Old Oct 11th, 03, 05:02 PM
1/8" is awfully close. Beside the heat issue, I'd be worried about the header hitting the fuel line in the course of normal operation, and wearing a hole in it. I had a similar problen, so I cut the steel line and spliced in a new section with a brass compression union.
BPOS is offline
