780 vacuum secondaries - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 13th, 03, 05:28 PM Thread Starter
I just put the original 780 4053 carb with vacuum secondaries back on my 396/375 engine. When the engine is idling and I open the throttle wide open, the secondaries never seem to open. Whats up? Kevin
68SS 396/375 L-78
68SS 396/375 L-78 Camaro
68 Chevelle
jus4funn68 is offline
post #2 of 4 (permalink) Old Jul 13th, 03, 05:40 PM
Angry
They aren't supposed to open like that. Perfectly normal. You need to be putting a load on it while driving for it to open. That is the beauty of vacuum secondaries. They know when to open only when needed. [img]smile.gif[/img]
-Mark.
stingr69 is offline
post #3 of 4 (permalink) Old Jul 13th, 03, 08:01 PM
Yup yup. Thats the way it goes. It wont deliver unless it needs to deliver.
chicane67 is offline
post #4 of 4 (permalink) Old Jul 14th, 03, 02:37 AM
Quick trick to see if they open and how much is to use a twistie in the rod for the diaphram tighten only enough to hold it, not to stop it. Make a run down the street and see if it moved. Only opens under load.
68 Camaro~LSx ~all motor
